Reply 20 of 29, by Paadam
- Member
It actually did not make any difference whether I used the AUX 3.3v connector or not. And note that I only had stability issues when running at 133 MHz FSB, it is most likely rock stable at lower speeds.
Problem with XG-DLS is that it does not have oboard 3.3v regulation unlike most BX boards fr example. It has HIP6018BCB instead if more common HIP6019BCB (which is used on P2B-DS and many other boards and has 3.3v regulation) and thus it cannot compensate for different VIO voltages. But there's nothing that some tinkering wouldn't fix 😉
wrote:It's good to see the board got into the right hands... You certainly know your way with hardware hacks 😀
Meanwhile 486 boards are still waiting for some spare time 🙁
Thanks man! But at least you can be sure that the boards work, I tested them 😀
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
