Reply 20 of 88, by Ozzuneoj
- l33t
wrote:Yes it existed. The one I have now (754 SLI) is this board for some more information and pictures for you: http://www.newegg.com […]
wrote:Wow, I didn't even know such a thing existed. I own an Abit Nforce 4 SLI board for socket 939, but I honestly thought it was a typo when you said yours was 754.
Those must have made for some really unbalanced systems back then. 754 didn't leave much CPU head room compared to 939. Lower speed per clock, lower clocks and no dual cores. Really unusual setup though. I'd wager that there aren't many of those left. 😀
Yes it existed. The one I have now (754 SLI) is this board for some more information and pictures for you: http://www.newegg.com/Product/Product.aspx?It … N82E16813123257
As you said, unbalanced system as I'm coming to find out. Even with a +26% overclock on the CPU up to 2640 mhz and running 1.5 GB of DDR @ 528 mhz, it's still pretty darn shitty performance with my pair of 6800 ultra's in it. Or any game really. So I decided to go browsing ebay last night for a replacement.... I already own an amd socket 939 nforce4-SLI system for 939 but it's proving to be extremely flakey and won't come on half the time and a chat with someone else confirmed his 3 nforce4 939 SLI systems also do this.. 3 different boards from 3 different vendors. So 939 is just troublesome and not reliable and flakey in general.
So I was looking for something better cheap when I stumbled upon this:
Seller's ebay photo.
Asus Crosshair, AMD Socket AM2+ & nvidia 590-SLI Dual-16x-SLI system for $39.95 free shipping.
Should be quite the step up from this 754 system. I already own an AMD 3-core cpu to get started with, and I have a set of kingston DDR2-1066 overclocking ram, and this is a big designed-to-be-overclocked board.
Seller said it was tested and fully working so hope it works out well for me. This will also officially be the fastest / sexiest AMD setup I've ever owned in my life. It supports up to Phenom x4 unlocked quad cores to play with, and all of the AM2 / AM2+ dual cores. So kind of excited to get to play with a nicer AMD system for the first time ever. Previously the best AMD system I'd ever owned as 939 systems.
That should be interesting to mess around with, for sure!
Honestly, I can confirm, a reliable Nforce 4 SLI board seems to be a rare thing. The one I have is Abit's top end AN8 32x model. My brother paid out the nose for this thing back in the day. It ended up with bad, leaking caps after several years of light use (not much gaming, running a 4200+ and a single GPU). I replaced them and got it working again, and it only worked right for maybe a year before it started getting flaky again. Last I tried, it didn't turn on at all.
On the other hand, I've never had any problems with my EPox 9NDA3J Nforce 3 Ultra S939 board... its older, was used in some pretty awful conditions for many years after I sold it to someone, and when I got it back it still worked perfectly. I plan on upgrading the BIOS in that to the final beta version that supported dual core CPUs, then trying the 4200+ from the Abit board in it. Along with an AGP BFG 6800 GT OC, it should make for a pretty awesome 98SE+early XP rig whenever I get around to putting that together. I do wonder if my DFI Lanparty Nforce 4 Ultra board is still kicking somewhere though. That was my first PCI-E board and it was fantastic (even the box was awesome, I still use it to hold motherboards and it hasn't collapsed). The only thing that tempted me away from that (and away from AMD for good) was the phenomenal performance\value of Intel's Core 2 Duo E6750 on the P35 chipset.
