Reply 20 of 24, by MrMateczko
I didn't say you need KernelEx, just use an older version of 3DMark03 (earlier than v360), like this one:
http://i.download.idg.pl/fannef/d174ff5d14f42 … DMark03v340.exe
I do know that X850 XT is better than 6800 Ultra. And maybe I will buy one, since I can. Damn you retro PCs you just make me buy more outdated stuff just for the fun of it! 😁
Reply 22 of 24, by MrMateczko
*that feeling when you realise you had the screenshots all along, facepalm*
So yea...those are the results I was meant to post in the OP 😀
My current main PC - I chose the dedicated GPU, which is the GeForce GT 740M, SystemInfo lies!, also low score:
My brother's new PC:
Reply 23 of 24, by Standard Def Steve
gdjacobs wrote:
Standard Def Steve wrote:
3DMark2003 is not CPU dependant at all. I can hit 10K in 3D'03 with a PIII-S @ 1575 and 6800GT. And pairing that 6800GT with a 2.8GHz A64 only increases the score to 12.9K.
I don't think you mean what you said. It is hitting a scaling limit as CPU power increases, but it certainly hasn't hit that limit on your PIII-S. An A64 appears to remove that limit let alone a C2D. However, the fact that there was an increase at all indicates some CPU dependency.
You're quite right. I realized how retarded my statement was the minute I posted it, but was too lazy to edit it. What I meant to say is that 3DMark03 is mostly GPU dependant. 😀
Since everyone is posting their results, I might as well post a few.
PIII-S @ 1575 with DDR, GeForce 6800GT, XP SP3:
494.27 KiB
Athlon 64 @ 2.75GHz, X1950Pro AGP, Win7:
525.08 KiB
Mobile C2D T5600 (1.83GHz) paired with a desktop GeForce 9800GT. This shows just how little 03 cares about CPU speed. 30.5K on a 1.83GHz CPU!
387.69 KiB
Opteron 185 @ 3GHz, 2x 8800GTS-640MB in SLI, XP SP3:
76.36 KiB
Core i7 4930K @ 4.6GHz, GTX970 overclocked to 980 level of performance, Win7:
1.31 MiB
Reply 24 of 24, by Paadam
I got 11024 points with my Supermicro P3TDE6 with dual PIII-S 1.4GHz, 2GB RAM and 6800 (vanilla, non-Ultra, but pipelines opened and slight overclock (~10%). With Xp.
Many 3Dfx and Pentium III-S stuff.
My amibay FS thread: www.amibay.com/showthread.php?88030-Man ... -370-dual)
