First post, by NJRoadfan
I'm running into problems with this board and running a 500Mhz K6-2 CPU. The machine is 100% stable with the 350Mhz K6-2 it has been running since 1999, it randomly reboots in Windows when running the 500Mhz part. I ruled out other parts as being faulty along with heat issues. Here is the real kicker, the same 500Mhz CPU runs fine in an Asus P5A-B v1.04 board that I have here! (same board, but AT form factor and older revision) I strongly suspect the 1.06 revision of the P5A has more problems then realized outside of the reported issues with K6-2+ and K6-III parts. Anyone else have success running faster CPUs on this board? Here is the complete configuration for those wondering:
-Asus P5A v1.06 with latest BIOS, no onboard audio
-128MB PC100 SDRAM
-Western Digital 4.3GB HD (single platter!)
-Plextor UltraPlex 32X CD-ROM drive
-Some Jaton branded Intel i740 video card
-Adaptec AHA-2930 PCI SCSI card
-AWE64 Gold
