First post, by emosun
- Oldbie
So after watching this video
www.youtube.com/watch?v=xAgJ5aM3etc&t=163s
i tried a k6-2 266 on my packard bell m415 which yielded a no post. I then tried a k6-2 450 which did work , however it posted as an unidetified cpu at 66mhz. Within windows it shows as a k6-2 with no speed identified. The cpu however seems to perform identical to the 233mhz mmx. I'm wondering if boards have to have bios updates to supports these cpu's fully or not. I'm assuming that since the bios can't identify it it probably can't actually fully support it. the system uses the stock motherboard but with a riser from an L190.
