First post, by Jade Falcon
So in putting together a dual 1.4ghz setup. Right now I'm debating on getting a pci ata/ide 133 card.
Would a ata 133 card be worth while when the mobs only had ata66?
My thought is with 2 ata 100 supported drives it would be beneficial given that the mobo only has ata 66.
Now the drive in use of sent new or modern, two old Quantum Fireball Plus Drives.
Would a ata card be worth the trouble?
