Malvineous wrote:Thanks for the replies. I do have a Socket 3 board already with a clip-on cooler, but the socket has lugs on it that appear to be for attaching a cooler, and they look quite similar to what you see on Socket 370. Here's a photo from Vogonswiki of a socket like mine. They look a bit more secure than attaching to the CPU itself.
Do you mean to say that these lugs are not present on all Socket 3 boards? Now that you mention it, I have seen a special tool to remove 486 CPUs from the socket which strikes me as odd given it's a ZIF socket, so I'm guessing that means there must be variants of Socket 3 that are not ZIF and/or don't have those lugs.
So perhaps my question should really be - are there CPU coolers that attach to this ZIF style of Socket 3 with the lugs, and if so, are they compatible with any other sockets too?
No, they are not on all Socket 3 boards. Some Socket 3 boards, and indeed Socket 1 boards, have a LIF socket. You need to push it firmly into the socket in order to install the CPU, and the tools were likely chip extractors, just very big. It can be removed with a swiss army knife quite easily, or with a screwdriver, etc. If you want to see one, Phil has a video with his Biostar mobo, you'd need to dig a bit.
And as for that, you can try a Socket 370 cooler if you think it would work. For all I know that's exactly why they are there, but don't go looking to buy a Socket 370 cooler. It's entirely possible it's proprietary, and in that case, you might as well spend 10$ on a clip on cooler
And as for security, they are strong enough to not only take the CPU with it when you remove it, but it will hold the weight of the board as long as the socket will.
They are actually impossible to remove vertically and need to be slid off.
Also, installation tip, remove the fan by pulling it off, remove two of the clips, add your thermal compound, add the heatsink, and then slide the clips on to hold the CPU. Afterwards, put the fan back on. It is WAY more easier, and there is less chance of snapping the clips.
