First post, by Carlos S. M.
I was in some scrappers place and i stumbled with two interesting computers, a custom build with an Abit AI7 and another custom build with an Intel D865PERL, he sells for 5 € each PC and he can make offers if i get multiple PCs, but idk if it might be worth getting them, i know the AI7 on that PC is in good condition, but i'm not really sure about the Intel D865PERL since i didn't look it enough. i didn't take pics, but the Intel D865PERL looked like the one of the pic attached. Both are complete PCs with all parts
I'm considering getting them in the next days
Reply 1 of 28, by dr_st
The AI7 is a known nice board. The black version of the D865PERL is also nice, unlike the cut-down green version. For starts, it has the proper set of jacks for 6-channel audio.
For 5€, I'd be willing to bite the bullet, and grab both PCs. Even if one or both boards are bad, it's not a big loss.
Reply 3 of 28, by kenrouholo
I dunno what it's worth to you. Maybe you could resell and make a little money, but not much. Also your signature here says you have quite a lot of Pentium 4s already. (I'm also personally biased against P4 as Netburst was a terrible architecture, but clearly you disagree in some way or you wouldn't have so many of them.)
Both boards should be pretty decent I think. Both 865 so they'd be fine for 98SE through XP or so.
Yes, I always ramble this much.
Reply 4 of 28, by Carlos S. M.
Yeah, i'm considering getting these, if one of both boards are dead, i still get lot of stuff there, the Abit AI7 PC has a Radeon HD 3450/3650 AGP and 2 SATA HDDs as i saw, the CPUs might be useful as well. Also i forgot to say i found an old Athlon 64 i'm considering as well because of the Epox mobo, high end DDR kit and the geforce 3
Reply 5 of 28, by Carlos S. M.
Well, i actually like to collect CPUs in general, but the majority of them are P4 as my signarure says, i know Netbrust has it's shorcommings and it wasn't the best compared to AMD K7 or K8, the main reason is the boards since i don't have really much spares for 865PE mobos, i only have a Gigabyte GA-8IPE1000-G (in a build) and a Biostar P4TSE (spare) and i have the oportunity of getting more i865PE mobos which are known to be good, also i looked for an Athlon 64 build i'm going to pick as well
Reply 6 of 28, by Skyscraper
Get some moving boxes and some ESD bags, you can get 15 - 20 motherboards into a single moving box. In a "walk in wardrobe" you can stack perhaps 1000 motherboards or so if you are good at Tetris.
Reply 7 of 28, by kenrouholo
Well, for the price, then I'd say go for it. If you've collected so many P4 CPUs then might as well have a few decent boards to use them in. You don't have to defend why you collect them. My prior response was mainly pointing out how many of them you said you had, but I didn't realize you had so few motherboards for them.
I wasn't into P4s but I remember that the PERL was a pretty well-liked board at the time. I had some Abit boards but I don't know much about the AI7. I did Google it and it seems like another good one. I did like Abit in general, except on boards they had capacitor issues with (they had this issue with some boards and not with others).
Reply 8 of 28, by Tetrium
It may be more efficient to shoehorn spare components into the nicest computer cases and if one is to use a larger box for motherboards, I would recommend to put sheets of cardboard or perhaps that foam stuff between each motherboard to prevent accidental scratches (it's not a lot of effort and it will make moving the boxes around a lot less hazardous 😜). And I prefer to put in the motherboards sideways instead of on top of each other as this makes for less weight on the bottom boards (and thus also less flexing and less scratches and less broken stuff) and it will be easier to search through the boxes looking for any particular board (yes I know from experience 🤣).
Stacking 1000 motherboards like tetris will not work duu to the weight on the lower laying motherboards (yes I know you were being ironic 😁).
My retro rigs (old topic)
Report spammers here!
Reply 9 of 28, by Skyscraper
My boxes tend to look like this, they fit about 15 motherboards. 😀
Reply 10 of 28, by Tetrium
Dang, I will have to wait for daylight tomorrow and I will show you mine 🤣 but it does pack a lot of boards in little bit of room.
But it really looks very similar to how I kept some of my boards back when I had very little packaging material but I do pack every board in an individual ES bag.
I'm pretty sure I got at least one box with 15 motherboards...
Reply 11 of 28, by Frasco
I would never stack more than 2 motherboards.
I would never squeeze them. That would drive me crazy!
**skyscraper did a nice job there 😎
I would never ask about purchasing 3 computers in promo!
Sure I am biased cause I can't have a AGP like that for €10-15!
Even so, what you're asking es una barbaridad, Carlos!
Reply 12 of 28, by Carlos S. M.
Update 9th March 2017
I acquired the Abit AI7 computer along with an Athlon 64 PC, going for the Intel D865PERL build tomorrow or another day. I already told the guy to keep it for me
Will send pics later
Reply 13 of 28, by Carlos S. M.
some pics of the PCs i got, the P4 with the Abit AI7 had the mobo fautly, it doesn't boot with anything installed on the AGP slot (stuck at error code 25 on the two digit screen), the Athlon 64 PC turned out to be a Sempron 3100+ Socket 754 system with 512 MB RAM and the Geforce 3, the socket 754 works excpet for one of the RAM sticks. I hope the other PC with the Intel D865PERL works
P4 PC specs:
Intel Pentium 4 3.0E Prescott Socket 478
Abit AI7 Motherboard (fautly)
1536 MB RAM DDR 400 (3x 512 MB)
Radeon HD 3450 AGP 512 MB
120 + 250 GB HDD SATA (both HDDs SATA)
UNIKA "480" watt PSU (likely dead)
2x DVD drives
floppy drive
Gigabyte G-power cooler
Socket 754 PC specs:
AMD Sempron 3100+ with 64 bit enabled (i have a Sempron 3100+ as well, but mine is the one with 64 bit disabled)
EpoX EP-8HDAI Pro motherboard
512 MB RAM DDR 400 (256 MB x2, probably one of the sticks is fautly)
nVidia Geforce 3 64 MB
160 GB IDE HDD
PC CASE 300 WATT PSU
2x CD Drives
floppy drive
AMD Stock cooler
Reply 14 of 28, by yawetaG
The case on the P4 is a Cooler Master case, just repainted one with the same internal design.
Reply 15 of 28, by gdjacobs
I like the tool free mechanisms on the S754 machine.
Reply 16 of 28, by Carlos S. M.
Edited last post, posted the same pic again by accident + i missed one image of the P4 system
Reply 17 of 28, by Carlos S. M.
The P4 uses some no brand case, i don't see any Cooler Master Brand there
The socket 754 machine uses an NXZT Nemesis Black case
Reply 18 of 28, by Frasco
Abit AI7 🤑 🤑 🤑 (In fact I wanted to draw a heart instead of money)
It's good when the motherboard is talking to you.
25 is related to RAM, video card, IDE cables/drives and keyboard.
Someone changed his keyboard to a wireless one and voila...
Or there is some short on the board somewhere. Remove the motherboard from your case.
Although take heed to what someone wrote:
"I tried unplugging everything, and it only displays the error when I plug in the graphic card....."
Loved the Gigabyte power cooler. Your star is shinning very very bright.
Looks like there is one screw missing in it and the flat cable is dirt (last photo)
😀 I am nuts. My people say:
- It will be fine and totally fixed with 3 screws. I say no, no, no.
- It will be inside the case. I say no, no, no.
NXZT Nemesis Black case 🤑 🤑 🤑
Look at that case . Nice color and easy to use.
Carlos, I think you made a good choice, better than that! I'm up to no good with words, but I
get happy just looking at these stuffs..
Reply 19 of 28, by Carlos S. M.
I tried going to the same place to get the other PC with the Intel D865PERL along with an old Fujitsu PC with an AMD Duron and a Dell Dimension 4500, but couldn't take then since there was too many stuff placed which wasn't possible the acess to them for now, but luckily, he brought some more computer including two beige case goodies which i decided to take them home asap before someone takes them (the guy is still keeping the D865PERL PC along with the Fujitsu and Dell Dimension for me). Both PCs have beige cases and are working
the PC at the top is an old Duron system with missing parts when the one at the botton is a complete P3 system
AMD PC specs:
AMD Duron 1000 (Morgan, DHD1000AMT1B)
ECS K7S5A
no RAM
no videocard
no HDD
LG 52x CD drive
floppy drive
250 watt PSU
Pentium III PC specs:
Pentium III 733
QDI Advance 10T (supports Tualatin)
512 MB PC133 (1x 512 MB)
ATI Xpert 128 16 MB (Rage 128 GL)
80 + 40 GB IDE HDD (WD800BB and WD400BB)
HP CD writter
floppy drive
300 watt PSU
The PC boots Windows XP
