First post, by kaputnik
- Oldbie
Been thinking of trying to build a Via C3 system around some parts I already have. Got no prior experience of C3 CPU:s at all, got no idea what to expect, so please bear with me. Any input or thoughts on this will be appreciated.
The mobo is a MSI MS-6119 v1.1, CPU PnP (soft menu for FSB/multi settings) version, a Slot 1 440BX board. Latest BIOS for the soft menu version of the board (p2.9) installed. Sadly, its voltage controller is of an older type, SC1152CS, that only can supply 1.8-3.5 volts, so I'll have to find some way to get the lower voltage the C3 needs. I'm assuming running it at 1.8V is a bad idea, or simply won't work.
There seems to be MS-6119 v1.1 boards with a newer voltage controller, SC1152CSW, that can supply 1.3-3.5 volts. Could it perhaps be possible to simply replace the voltage controller on my board with one of those?
Even with adjusted voltage, can I expect an old Slot 1 board to be able to boot the much newer and somewhat obscure C3 CPU? Getting the impression that there are some quite significant differences between C3 and Intels counterparts, and that the board might have to specifically support it.
The mobo's max multiplier is 8. Planning to run FSB at 100 MHz to avoid OC'ing the AGP bus, so max clock will land at 800MHz. The whole point of this build is flexibility, performance is a secondary question. Got an Athlon XP 2400+ and a Coppermine 1100 rig for that.
The slotket I'd like to use is a 370SPC. Haven't found any reliable info on its make. Modded one for Tualatin CPU:s, tested successfully in an Abit BH6 board that can supply the right voltage. Got a few of these slockets, they take everything I throw at them when it comes to Coppermine CPUs at least, and modding one of those would be my preferred way of getting the right voltage.
Then I'd of course have to pick up a C3 CPU. Thinking of a Nehemiah, mostly for the full speed FPU. Assuming that underclocking won't pose any problems. Any other recommendations? Are there any good reasons to pick an Ezra-T instead?
So, guys, what do you think? Is there any hope? I'm not afraid of soldering, got no problems doing mods in the crazier category if required, as long as they aren't too experimental. I'd actually rather work with what I already have than trying to get my hands on one of those slockets with onboard VRM.
