First post, by Cohen
Please, does anyone knows model of this mainboard?
It's Socket 3, 486 motherboard, from manufacturer Informtech Industrial. I don't know model and can't properly set jumpers.
Works with 486 AMD DX 40 MHz. Also with IBM DX4 100 MHz but shows IBM CPU as DX2 100 MHz. Both are 5V CPUs. I'm afraid to try any 3V CPU at this moment because I don't know how to set jumpers. Need manual or at least exact model.
    3.18 MiB
    Unknow mainboard model
Reply 1 of 4, by Deksor
Tell us what is the POST string (the string found at the bottom of the screen where the bios counts the ram), it often helps
Reply 2 of 4, by Cohen
Sure.
As you can see from attached picture
(C) American Megatrends Inc.,
41-0109-428005-00101111-101094-SIS4967-H
    259.78 KiB
Reply 3 of 4, by TheMobRules
According to this site, the manufacturer is:
8005
AVT Industrial Ltd.
http://www.avt.com.hk/
Not very helpful, so your best bet is trying to find your board in TH99:
http://www.uncreativelabs.de/th99/m/m486_i1.htm
http://www.uncreativelabs.de/th99/m/m486_i2.htm
Reply 4 of 4, by Cohen
TheMobRules wrote:
According to this site, the manufacturer is: […]
8005
AVT Industrial Ltd.
Thanks
