First post, by oeuvre
I want to put my Skylake build into an older beige tower. I have the complete system and just looking for a good condition ATX white/beige case. It must have front panel pins that are standard ATX (so those legendary Dell Dimension XPS D/R/T series are a no)... I live in US. Anyone know where to get one in good shape or if you know a reliable decent model to get from Amazon or elsewhere? Thank you
Reply 1 of 17, by Jade Falcon
Rank BANNED
BANNED
a bit on the big side, but the Intel SC5250-E would fit your needs.
1ghz tbird setup.
Id opp for a old server case, it will have the cooling you need and likely support AXT boards.
Reply 4 of 17, by oeuvre
On Rakuten but they're sold out 😒
Did find htis https://www.nexhi.com/en/nexhi-case-atx-front … mid-tower-beige
Reply 5 of 17, by oeuvre
Okay so apparently it is the same one as this https://www.newegg.com/Product/Product.aspx?I … N82E16811162041
I ended up buying it anyways, it was $36 total including shipping. I got the front panel of the Dimension XPS T500 case to work with standard layout ATX motherboards by sticking a needle into a blocked pin and removing the filler. Tested it and it works great. Ordered a couple of 92mm PWM fans and going to replace my cooler with a smaller one cause it's too big to fit.
Reply 6 of 17, by Rhuwyn
Are you just looking for something white/beige period or are you actually going for a retro look? There are still new white cases available after all
Edit: http://www.ebay.com/itm//301743209787? Case in point.
Reply 7 of 17, by oeuvre
Retro look... I hate how oeuvrestylized most new cases are. Fractal Design does make some nice cases but I like the idea of dumping new hardware in an old case.
Reply 8 of 17, by Jade Falcon
Rank BANNED
BANNED
I'm the same way, I can't stand the look of new cases.
I have a dual 1366 workstation in the server case I recommend.
I would not want it any other way
Reply 9 of 17, by Rhuwyn
I just bought several of these. They are nostalgic for me because my first Custom machine sporting a Pentium 2 was built in one of these.
https://www.amazon.com/gp/product/B014GB4JYQ/ … 0?ie=UTF8&psc=1
Reply 10 of 17, by Rhuwyn
Jade Falcon wrote:
I'm the same way, I can't stand the look of new cases. I have a dual 1366 workstation in the server case I recommend. I would no […]
I think I am a bit more flexible then most of us. I don't mind modern cases as long as they aren't gaudy and loud. i like my cases to be sleek and straight forward.
Reply 12 of 17, by Gatewayuser200
Front panels can be rewired very easily.
"network down, IP packets delivered via UPS" - BOFH
“The bitterness of poor quality remains long after the sweetness of low price is forgotten” – Benjamin Franklin
Reply 13 of 17, by oeuvre
Actually there is one pin that is sealed shut so I stuck a needle in there and removed the filling. Fits into my mobo's headers perfectly and works.
Might just pick up another one of these cases and do the same trick
Reply 14 of 17, by Gatewayuser200
Just for reference, another slick trick with proprietary front panels is to buy some 1P pin housings (or even 2P) so you can pull the pins out of the original connector and put them into individual plugs.
http://www.ebay.com/itm/131413159465
For the super evil front panels you may need to cut the ends and crimp on entirely new connectors instead of just swapping the housing. The supplies and tools for this are also easily available on fleabay and they just crimp on so it's not hard to do.
Reply 16 of 17, by oeuvre
Found a case, just gonna use a Dell Dimension 4100 I found for cheap on eBay and swapping in a faceplate from an older Dell Dimension P133
Reply 17 of 17, by techgeek
Just a week ago I ordered this case: http://www.ebay.com/itm/Brand-New-PC-Mid-Towe … 872.m2749.l2649. It is beige, except for two small colored plastic pieces on the front panel (the top one can be replaced with a smaller plastic cover that was in the box, thus freeing one more 5.25" bay). Their listing says that you may select from the three colors that they have available: dark blue, bright blue and red - although, I explicitly wrote them that I want the bright blue, I got the dark blue case. When it showed up yesterday it turned out that the dark blue doesn't look as awful as in the pictures. It comes with a power supply for a little over $30 shipped. It seems that it might also be easy to convert it to an AT type case, but I needed it for my PII build.
    526.68 KiB
