First post, by Stojke
- l33t
Hi guys, does any one have experience with MHDD and SCSI disks? I have an Seagate ST34572N disk drive which had some slower sectors in MHDD scan so I decided to issue the SCSIFORMAT command to see will it fix those sectors with an full format. But all it did after it finished is make my disk not respond at all any more. As if it deleted its geometry and capacity information. Windows still sees the disk drive via device manager as disk drive and under its properties as its original name but it has no info on it nor is it visible under disk manager.
Is it possible to recover from this problem?
