First post, by Baoran
I saw someone selling some old hardware really cheap online. They did only cost 6 euros, so I decided to take a risk. I only know that there is a 486 motherboard and some isa cards, but I don't know anything else about them based on the low res picture that seller had posted.
Now that I have bought them, I have been trying to figure out what did I exactly buy.
Here is the low res picture that the seller had posted:
367.11 KiB
I know most of you probably have more experience with old hardware, so if any of you recognizes this motherboard or any of the cards based on this picture, I would appreciate it.
Reply 1 of 16, by peklop
COR333 is a Sony at-bus CD-ROM interface card.
Big 8-bit car is a CD-ROM controller too.
16-bit card is a Netware compatible 10 mbit ethernet card.
Reply 2 of 16, by Munx
The top right and bottom left cards look like CD-ROM controller cards, the top left seems to be a serial/printer IO card and the bottom right looks like a modem.
My builds!
The Underdog - The budget K6
Reply 6 of 16, by melbar
lazibayer wrote:
The mobo has socket 3 so it may support pentium overdrive.
The socket on the picture looks like the socket 2...
http://www.vogonswiki.com/index.php/Socket_1-3_Motherboards
#1 K6-2/500, #2 Athlon1200, #3 Celeron1000A, #4 A64-3700, #5 P4HT-3200, #6 P4-2800, #7 Am486DX2-66
Reply 7 of 16, by Baoran
After going through pictures online. I think I might have found the motherboard: http://stason.org/TULARC/pc/motherboards/D/DT … -PKM-0037S.html
I have 486dx-33Mhz and 486dx2-80Mhz. It does not seem like that motherboard goes up to 80Mhz, but at least I will be able to put the 33Mhz cpu in it.
Reply 8 of 16, by cyclone3d
If it doesn't do 40Mhz bus speed, you can always put the DX2-80 in it and it will just run at 66Mhz.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 16, by Baoran
thanks. The reason I bought that so quickly was that my old 486 motherboard died recently without any warning and all the ebay prices for 486 motherboards were so high that I was willing to risk 6 euros not knowing if that motherboard will work or not.
Reply 10 of 16, by krivulak
Well, to be true, for me 6 euros is a great deal in every way, I would put that money just for the CPU for my pre-Pentium collection.
Reply 11 of 16, by Baoran
I just received what I bought. Here is a picture of the motherboard. Looks like a very clean 486 motherboard to me. Cpu is 33Mhz and I just need to remove the battery.
4.71 MiB
Reply 12 of 16, by Baoran
and of course there is some nasty corrosion under the battery...
Well, what can you expect from a motherboard that only cost 6 euros. Still disappointed.
3.26 MiB
Edit: I checked things out with a multimeter. Surprisingly it seems that both of those corroded connections are still connected to the keyboard port. Unless I checked out something wrong.
Reply 13 of 16, by Baoran
I have a question: All my other motherboards only have 1 tag chip slot, but this motherboard seems to have a 2 slots for tag chips. In what situations you need 2 tag chips? If I have a set of 8 cache chips of total 256Kb cache and those came with only 1 tag chip, is there any chance for them to work with this motherboard?
Reply 14 of 16, by Erik765
If the board requires two, you'll need to use two.
You can try with just one, as this certainly wouldn't harm anything, but I doubt it will work.
It's not uncommon for a board to require two tags depending on the board.
Reply 15 of 16, by CkRtech
The corrosion isn't too bad, actually! 😀
Good to hear that your multimeter check was positive, but you still want to neutralize the corroded areas with some vinegar. You may also want to desolder the keyboard connector for scrubbage/investigation/replacement as needed. I wouldn't be stingy with the area you work. I can see a little bit of corrosion on some IC legs and battery pin header as well from the photo. Obligatory rinse/get dry/etc... after you are finished.
Congrats on your board.
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
Reply 16 of 16, by Baoran
Only thing is that the motherboard only comes with 4 32Kb cache chips and 1 32Kb tag chip even if the motherboard manual here http://stason.org/TULARC/pc/motherboards/D/DT … -PKM-0037S.html basically doesn't seem to have any options where any of the cache or tag chip slots are empty.
