First post, by Kynrek
I installed 98micro from the 98lite product. I had two issues that I was able to overcome and I just though I'd share.
The first issue was easy, the Voodoo3 drivers would not install without internet exporer 4 or higher. Luckly 98lite allows you to go to add remove programs and you can just add internet explorer as a windows feature (this still keeps it from integrating into windows explorer so you keep your speed)
The second issue is simple to fix but it was a pain. I installed the windows 98 USB mass storage drivers that I found from Phil's Computer Lab's website usb33e. After installing the drivers and rebooting I couldn't even get into windows because explorer would cause an illegal operation and crash. I found a newer version of the mass storage drivers usb36e but had the same issue. I found that you can actually extract usb33e.exe and see the contents. Sure enough there is a copy of explorer.exe that ends up replacing your windows explorer.
I reinstalled 98micro and copied explorer.exe from C:\windows in my 98micro install into the extracted usb33e folder and overwrote the explorer.exe then ran the batch file to run the installer and sure enough everything worked!
