First post, by Der_Richter
Hi
First post, after using this place incognito for years when searching info. Now i have a slight issue of my own. You see, i recently acquired into my collections a very nice condition QDI MP4-P4U885P3 motherboard that i would like to preserve in a new build. Same as on this link:
http://www.amoretro.de/2012/09/qdi-mp4-p4u885 … otherboard.html
Looking at it this evening i noticed the odd fact that it has an onboard EIDE controller, but no other IO on the board itself. Also it lacks a riser board for that. So, seeing that there are only two "large" EIDE connectors on the board, what would be the way of choice of hooking a floppy drive to it (standard 3.5in), as i would need that for some old software?
If i need to get a floppy board separately, PCI board perhaps, would there be any considerations as to compatibility?
HDD @ 4Gb. works fine on the controller itself, BIOS picks it up, so that seems fine, but i really need a floppy on this machine.
Thank you in advance. And finally, after all years of lurking, hello 😀
Preserver, refurbisher, collector. In that order.
