First post, by greasemonkey90s
Well at first i had trouble understanding the jumper settings so i thought that was the reason i fried the first voltage reg. I resoldered a new exact one and again i tried and its pop'd it. Im thinking its my voodoo3 agp. Its rev a 1.2a
Reply 1 of 4, by fitzpatr
It is your Voodoo3. It pulls too much power for that board revision to handle. Your card is probably fine, but you cannot use it with the FIC VA-503+ or PA-2013...at least before Rev. 2.0.
FIC PA-2013 Ver 2.1 and Voodoo3 3000 AGP
MT-32 Old, CM-32L, CM-500, SC-55mkII, SC-88Pro, SC-D70, FB-01, MU2000EX
K6-III+/450/GA-5AX/G400 Max/Voodoo2 SLI/CT1750/MPU-401AT/Audigy 2ZS
486 Build
Reply 2 of 4, by greasemonkey90s
Yea i just googled but my v3 is fine actually. That was close. Ill replace it one more time and see if i can revive this board one last time.
Reply 3 of 4, by greasemonkey90s
But this is the va-503+ rev 1.2 baby at version of what u just posted which should have that issue fixed.
Reply 4 of 4, by The Serpent Rider
I think AT boards were never fixed, because they need this VRM for AT PSU.
