Reply 20 of 22, by Spiffles
Hey guys, having the same conundrum here. I'd like to build a system that has support for most of the popular and less popular storage media, and I realized the 5,25'' floppy drive is going to be the limiting factor on the system's age. So a Pentium 4 motherboard, aye? I also need it to take an IDE Zip drive and a SCSI controller card into which a 3,5'' magnetooptical drive would be hooked.
Anyway, this guy is using a Core 2 Duo motherboard and has a 5,25'' floppy drive working with no special drivers or adapters, though he doesn't simulatenously have a 3,5'' floppy drive in the PC.
https://www.youtube.com/watch?v=footqrNHfp4&t … channel=Jrcraft
Reply 21 of 22, by jakethompson1
Spiffles wrote on 2020-10-17, 15:26:
I have an ASRock 980DE3/U3S3 (ATX) which I believe is the most "modern" (still a stretch) motherboard with an onboard floppy controller. It can take an AMD FX-8350, which I have, and 32GB DDR3 RAM.
Like most later boards with onboard floppy it can only control a single drive. I'm using a 1.44MB. The BIOS also has support for 5 1/4" 360K and 1.2MB but I've never actually tested one with it. Some people have explored boards to see whether the single-floppy issue is a bios limitation or hardware one. On this board, it is a hardware one as even with Linux (which lets you override the floppy info in the CMOS) it doesn't do anything when you access the second drive.
There are adapter cables out there with usb on one end and a connector for an *internal* 3 1/2" floppy on the other. You might use that, in addition to a "real" 5 1/4" drive, so that you could have both internal drives on one machine.
I believe the reason for no PCI floppy controllers is that even if one existed, it wouldn't be a drop-in replacement for DOS compatibility due to needing to emulate ISA DMA--same reason why PCI sound cards have tricky DOS SoundBlaster emulation.
I wonder if, someday, people could hook a floppy controller to the TPM header on a modern motherboard, as I believe that just connects to the LPC bus (software compat with ISA) and there are some POST code cards that connect to that for this reason.
Reply 22 of 22, by pentiumspeed
I keep at least 2 computers, which are notebooks, both XP with floppy drive installed. Also quality USB floppy drive please. Not the one that cost 20, that thing had a plug was not USB dimensions spec was loose and making intermittent connections and eventually killed the little chip when got bricked. Next one I got was HP branded external USB floppy drive, much better quality.
Cheers,
Great Northern aka Canada.
