chartreuse wrote:Just went and measured the one AT case I had handy at the moment. (It was a Full height tower from around the 486-Pentium era) T […]
Just went and measured the one AT case I had handy at the moment. (It was a Full height tower from around the 486-Pentium era) This one had a circle that had two sides flatted on it. The diameter of the circle was 26mm (~1") and the width between the flats was 22mm (~0.9") -- If you take a 26mm circle and overlay a 22mm wide rectangle over it you'd get the shape of the opening.
Inset from the case and stood off closer to the motherboard was another opening for the keyboard connector, I couldn't quite measure it due to the depth but it appeared to be the same diameter as the width between the flats -- 22mm.
22mm would likely be a good hole size. You want it quite a bit bigger than just the diameter of the keyboard DIN connector as many of the keyboards from that era have a fairly large plastic moulding around the plug itself.
EDIT: I can probably also get you the measurement from my XT clone case over the weekend, see how it compares since I believe it is purely a circle.
Thanks! The XT measurement would help as well.
On the AT case, in which orientation are the flat sides in regards to the motherboard?
The 2 motherboards I am looking at, the keyboard connector is 20mm wide, but measured diagonally, it is about 25mm. I guess 22mm would work, it would just have gaps on the sides.. and if somebody fumbled really badly it would allow them to scrape the edge of the motherboard with the keyboard connector.
I'm not sure it would need to be that wide as this would be for an ATX style case with a custom I/O shield that is a lot thinner than what the old XT and AT cases were. I'll have to make a mock-up to test with before I decide on a final size anyway.
Looking at a ps2/AT adapter and an XT? keyboard (doesn't work on my AT boards and I don't have an XT setup to test on), the max diameter is around 16-18mm.
