First post, by Half-Saint
My old 486 often refuses to turn on. Sometimes it works, most of the time it doesn't.
Would there be an easy way of testing the power switch? It's either that or the PSU itself. Opened it up yesterday and can't find anything wrong by visual inspection.
Cheers
Reply 1 of 3, by kixs
Have you tried powering just the PSU with no lines connected (except 220V line)? To rule out any other components being flaky.
Reply 2 of 3, by CkRtech
If you go that route, you may want to put some sort of load on the PSU - maybe some fans with molex connectors and a spare hard drive.
Displaced Gamers (YouTube) - DOS Gaming Aspect Ratio - 320x200 || The History of 240p || Dithering on the Sega Genesis with Composite Video
