First post, by murrayman
Have a Western Digital Caviar WD200 20gb HDD from 2001. Been using it in a Win98 machine for the past decade with no issues. Recently moved across town and packed the computer in a box lined with packed air and blankets to prevent any shock during the move -- which didn't matter in the end since the box ended up being hand-carried and cradled in a car. 😜 When I unpacked it, everything worked except the HDD. I wondered if it finally developed a bad sector, but the BIOS didn't even see a drive was there. So I opened it up, powered it on, and was surprised to find it wasn't spinning at all. Took it out and hooked it up to an external power supply; when you feed it juice, it does nothing. No clicks, spinning, etc., as if it's not receiving power at all.
Any chance I could attempt a repair on this drive? Looking at the circuit board from beneath, I don't see any broken traces, so no visible damage from shock on the outside. Just not sure what else could have happened.
P3B-F 1.04, PIII 1k, 512MB PC133, GF DDR 32MB + DM3DII 12MB SLI, SB0100
P3B-F 1.03, PIII 700, 384MB PC100, V5 AGP, SB0160
CP 5170, PII 350, 256MB PC100, Rage LT 2MB, ESS 1869
PB M S610, PMMX 233, 128MB EDO66, DM3D 4MB, Aztech
