First post, by GabrielKnight123
I have a 3.2GB hard drive im trying to partition with Fdisk on a 386, in the Bios its setup for 3.2GB (3079MB) but I cant get anything higher than 504MB from Fdisk, is this a limitation of the Bios or is it the I/O card? When I run Fdisk it ask's if if I want to use the maximum available space and make it active, I choose yes and format the drive and its only 504MB...the same happens if I choose "No" at the start of Fdisk.
