First post, by bjwil1991
- l33t
My plan is to upgrade my motherboard+CPU+RAM combo to a better solution for my Windows 98SE machine due to incompatibilities with certain games (chipset issues), and some games require a faster CPU in order to play games at better frame rates.
However, I would like to use a SATA drive with this particular card: Syba SD-VIA-1A2S, which has a VIA VT6421A chipset on there, and I can actually boot from a SATA DVD burner with ease with that after I upgraded the BIOS. I did use this card with my Socket 7 build to run both MS-DOS 7.1 (bare-bones of Windows 98SE) and Windows XP Pro SP3 on a 120GB SATA HDD (went kaput, but I luckily archived the data that was stored on there) and worked successfully for MS-DOS.
Also, I believe this card allows to switch from AHCI to IDE mode as I know that Windows 98SE doesn't support AHCI mode (if my memory serves me right), or I can use the SATA ports on the motherboard (which is IDE mode only).
Motherboard combo I'm planning on using:
Chipset: SiS 760GX
I/O chip: SiS 964
AGP: Rev. 3.0 8x/4x
Memory type: DDR-400 (compatible with DDR-333/266)
Socket type 754
Processor Support: AMD Athlon 64 or Sempron
PCI Revision: 2.2
CNR slot (y/n): Y
Integrated I/O: CMI9761A AC'97 Audio, RealTek RTL8201BL Ethernet, SiS Mirage 2 GPU, 1x COM port, 1x LPT port, 2x IDE, 2x SATA
CPU installed: AMD Athlon 64 3000+ (800MHz FSB x 5 multiplier) @ 2GHz
RAM installed: 768MB DDR-400 (1x 512MB and 1x 256MB)
Add-on cards installed: Syba SD-VIA-1A2S PCI SATA Controller and nVidia GeForce 6200 PCI
HDD installed: 320GB Samsung SATA HDD <-- connected to the Syba SATA controller
What are your thoughts on this? The PCI controller card, or the whole motherboard combo, minus the card?
