Can you still buy AT cases new?
Reply 40 of 51, by candle_86
PCBONEZ wrote:
There are "spacers" aka Standoffs that have a pad instead of a pin that goes through the mobo pan. They just sit on the pan, th […]
candle_86 wrote:
Well alot of newer cases don't have the holes for a BabyAT board anymore, and with the cutouts some of them have plastic spacers dont work either.
They just sit on the pan, they don't go through it. No hole required.
They don't hold-down but they do limit board flex when installing RAM or add-in cards.
For hold-down the standoffs that do line up are sufficient.
Use metal standoffs and screws in those locations so the board is properly grounded to the case.
In a pinch you can cut the pins off the more common nylon standoffs which turns them into the pad type.
Been doing this since the 90's. It works great.
Also works for parts testing boards that will never see a case.
Keeps all the solder joints on the back of the board off your work surface.
I'm talking about where the case is missing metal on the tray for heatsink removal in modern cases, seen some rather large cutouts for that
Reply 41 of 51, by PCBONEZ
OIC
Those can be patched by soldering in a patch panel. Or use pop-rivets.
Personally I'm too lazy, ah, I mean busy, for that sort of project anymore and I'd just find a better case.
Just saying if you really really just gotta have THAT case you can make it happen.
Reply 42 of 51, by PCBONEZ
tayyare wrote:
Sorry, I jumped before reading the whole tread 😊
Coming late to the party is okay.
[passes tayyare a margarita]
Reply 43 of 51, by cyclone3d
Plasma wrote:
You don't need a hydraulic punch or multiple hole saws. A step drill bit will cleanly cut through sheet metal.
The io shields are way thinner than normal sheet metal. I could give a step drill a try though I guess. If I remember correctly it didn't go to well the last time I tried it on something that thin.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 44 of 51, by tayyare
PCBONEZ wrote:
Coming late to the party is okay. [passes tayyare a margarita] . […]
Thanks! 🤣
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 45 of 51, by tayyare
As an engineer/manager that spends 12 years (of his 25 years work life) manufacturing parts from sheet metal, I would say for a sheet metal that thin and flimsy, it (i.e. step drill) will not end in a good way.
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 46 of 51, by PCBONEZ
I suggested the two wood blocks and hole saw method partly because you are planning on doing a number of them.
If you set it up right the blocks will serve as templates so you won't have to spend so much time fussing with centering and aligning each one individually.
Reply 47 of 51, by the Goat
cyclone3d wrote:
I can get blank I/O shields for ATX cases for cheap. […]
All I would need to make AT style shields out of them would be a punch for the correct size hole. I would also probably have to make a holder to hold the I/O shield in the correct place when punching the hole with a hydraulic knockout punch.
If enough people are interested, I wouldn't mind ordering a bunch of plates and making AT plates out of them.
I think with shipping, I could send them out for around $7 a piece (maybe less) and they would be significantly cheaper per shield if more than 1 was ordered.
I would just be looking to cover the price for the punch as well as the shield and shipping.
The more that are wanted, the cheaper I can make them for.
To break even at the ~$7 a piece shipped to the USA, I would need to make about 20 of them.
I'm interested in one or two of those.
Reply 48 of 51, by PCBONEZ
Use PM.
Site admin frowns on trading.
Reply 49 of 51, by Azarien
PCBONEZ wrote:
Both the PCI and ISA in the shared slots lineup to the same slot in the back but you can not use an ISA and PCI at the same time in the shared slots.
I wonder if it is just a mechanical "sharing" (squeezing in one more slot taking advantage of PCI cards being inverted when compared to ISA) or there is some circuitry on the board shared making it impossible to use those two slots together (assuming that one manages to put a card into both).
Reply 50 of 51, by Tiido
I once managed to squeeze a really thin USB card on the shared slot (of course all connectors were put on cables and capacitors relocated to other side of the PCB).
Reply 51 of 51, by PCBONEZ
So far as the signals and data they can't be sharing. Different bus, different tech.
So far as the -power- supplied to shared slots, I don't think there is any official standard that covers that situation.
That would be up to the discretion of the manufacturer.
Never thought to look, this is speculation.
Most likely they do share the power paths to reduce the number of traces on the board.
That would only be a problem if the traces are too thin at some point to support the current to two cards.
Again, never thought to look on vintage boards, this is speculation.
I imagine -ALL- the slots on a board share power traces (to reduce the board space needed) and they would have enough copper in the traces to support a card in each shared slot.
--- I'm not going to say that all boards do that because as soon as I do a board will show up that doesn't.
I have occasionally seen people use both slots and for them it worked fine.
