Reply 20 of 22, by SpanK87
quicknick wrote:
Have you tried booting from a DOS bootable floppy with only the FDD connected and all IDE drives disconnected (and set to "none" in BIOS)?
You say POST is very slow. It is the same if you disconnect ALL drives?
I'm gonna try it right now.
LE:
It posts a lot faster now, but still...
Oh... and it looks like it's not even accessing the drive. The floppy green LED doesn't turn on.
Reply 21 of 22, by quicknick
Are you 100% sure that the drive, cable and boot disk are all in working order? Can you test them on another system? Unless you are certain they all work, this is a shot in the dark... (OK, if the LED doesn't light it means it didn't even try to read the disk, so the problem is likely the cable or the drive).
If your floppy cable has two connectors with a "twisted" segment between them, try also the other connector...
Reply 22 of 22, by Windows9566
My Packard Bell's Intel Orlando NV430VX had that similar issue which was the CD-Drive/HDD/FDD was not recognized
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
