Reply 140 of 147, by kaputnik
- Oldbie
evasive wrote on 2022-09-13, 16:26:The newer awdflash doesn't know how to backup this older award bios (happens quite often), as a result this is not a valid dump. […]
kaputnik wrote on 2022-07-02, 10:53:#: 120 Manufacturer/Identifier: IEI SSC-5X86H VER:C Chipset : ALi 1487/1489 BIOS : Award Modular BIOS v4.51G ID string : 06/28 […]
#: 120
ID string : 06/28/96-ALI-1487/89-2A4KDD35C-00Note that this image is a dump of the installed BIOS on my SBC, not an official update image from IEI.
Can you please use UniFlash instead?
https://www.rainbow-software.org/uniflash/
Redumped the BIOS with Uniflash 1.40. Compared it with the original dump, and indeed, it looks like Awdflash only managed to dump half of it.
How do you go about verifying the new dump by the way? Can it be done with CBROM, Modbin, or something like that?
Attached the new dump. Will update the original post once it's verified.
