chinny22 wrote:Onboard I/O controller will work and be better then anything ISA. PCI cards have dos support if you do want something more fancy […]
Onboard I/O controller will work and be better then anything ISA. PCI cards have dos support if you do want something more fancy then the onboard controller.
Same with network cards. PCI will work.
Unless I'm missing something only thing left is Sound, and yeh this wants to be a ISA card, so unless you have more then 1 sound card you'll still have 1 slot free.
I have 2 486's but really my P3 does everything fine if not better, I only use one of the 486's more as it has sentimental value (was our very first pc) but if I just want to play a dos game I use the P3. I doubt the other 486 gets used more then 24hrs a year all up
My 486 is around for sentimental value mostly.
I'm curious to know why an onboard (Winbond) legacy controller would be better than the standard ISA Multi - I/O board (2 Serial, 2x IDE, Game, 2x Floppy, 1 Parallel, card that's in my 486 now. Not that I don't believe you, but I'm wondering what the improvements are?
Also, in my PIII refurb/cleanup project I'd be using an ISA SoundBlaster AWE 64 Gold, it's in there now, though I do have an original SB16 from when they first came out. You know, the ones with the proprietary CD-ROM interface and WaveBlaster Daughtercard and socketed ASP chip. I assume the AWE 64 Gold would be fine.
The Abit BX6R2 has 2 ISA slots, and the second ISA slot would be equipped with a Supra 56K hardware modem. It's what's in there now.
I also have a Celeron 1.4Ghz on a slocket, and a P2-266 and P3-450 available. So if for any reason I needed to run slower I could drop down to 266MHz, otherwise I'm sticking with the Celeron/P3 @ 1,400 MHz.
What I'm thinking of doing is getting rid of the PCI SB-Live thats in there now. For the longest time I just use Stereo L/R out, and line-in/mic-in. Never got into that hypersonic quadraphonic swirling sound.
Currently the system specification is:
OS
Windows 7 Ultimate (tested)
Windows XP Professional SP3 (installed)
Windows 98se (previously installed)
Windows 95 (previously installed)
Windows 3.1 (pending)
Dos 6.22 (pending)
Mainboard
Abit BX6R2 motherboard, Slot-1, Intel BX440
CPU
Intel Pentium III Tualitin @ 1,403MHz, 100MHz FSB, 256KB full-speed L2 cache
PowerLeap socket 370 - slot-1 slocket adapter, with external power supply source
Memory
1 GB RAM (256MB x 4 SDRAM) non-ECC, PC-100/133 w/spd
Chipset
Intel i440BX
Winbond W83977EF-AW Super I/O
Expansion slots
2 ISA
5 PCI
1 AGP 1x/2x (3.3v)
Internal Onboard Connectors
2 x IDE ATA UDMA-33 connectors
1 5.25 & 3.5 FDD connector
4 x 168 pin DIMM connectors (data buffered)
SMI and instrument bus
Reset
Power
HDD indicator
Speaker
Keylock
BIOS reset
Wake-on LAN header
SB-LINK header
IR-1 IrDA TX/RX header
FAN x 3
RT2 thermistor
ATX power input connector
External Onboard Connectors
2 x serial 1650 UART
1 x parallel EPP ECP SPP
2 x USB 1.0
PS/2 keyboard
PS/2 mouse
BIOS
Award Modular BIOS v4.51PG 1984-1999
PnP ACPI DMI
4/26/2000
i440BX-W977-2A69KA1JC-QR (last version produced)
Graphics
Gainward GeForce 4 4600ti ultra PowerPack Golden Sample Ultra/750 XP
Dual DVI, Dual VGA, Video-in & Video-out, 128MB DDR, AGP 1x, 2x, 4x
1996-2002 NVIDIA 4.25.00.28.00 GFORCE 4600 TI 128.0MB
Hard disk drives
3 x Western Digital 120GB HDD (IDE PATA)
Floppy drive
Sony 3.5 Floppy
Optical drives
CD-ROM PlexWriter 24/10/40A drive (IDE PATA)
DVD52X Lite-On DVD reader SOHD 16P9SV (IDE PATA)
Auxiliary drive
Zip-100 Parallel port model
Modem
Supra Express 56.6k v.90 non-win-modem (ISA)
Sound
SoundBlaster AWE64 Gold CT4390 + memory module CT1930 (ISA)
SoundBlaster Live! CT4760 w/breakout box (PCI)
Additional expansion ports
Belkin F5U220 5-port USB 2.0 card NEC chipset (PCI)
Generic VT6306 based 3-port IEEE-1394 FireWire card (PCI)
Internal 1394 - ATA Bridgeboard
FW2IDE02D (Oxford FW911plus)
Ethernet Network NIC
3COM Fast EtherLink XL 3C905b-TX 10/100
Power Supply
Antec True 550
Fans
4 x dual ball-bearing Vantec & no-name generic
Fan speed controllers
3 x Cnps FAN MATE
1 x 3-speed controller and generic fan alarm
Front Panel Ports
1 Stereo line-in
1 Stereo line-out
1 Microphone in
1 CD audio headset out
2 x USB 2.0
1 x IEEE-1394 FireWire
1 x Compact Flash, SD, and multi-card reader
Additional audio expansion ports
2 x optical SPDIF In/Out
RCA optical SPDIF In/Out
RCA Aux-In
RCA Aux-Out
MIDI In/Out
1/4" Headphone Jack
4.1 analog surround out
1/4" line in jack
3 x 1/8" line in
6 Channel AC-3 SPDIF out
2 x RCA line out
Gameports
Standard analog PC gameports onboard the SoundBlaster cards
2 x DA-15 connectors
Multiplexed 4 x DA-15 connector box
Case
Generic beige-white in-winn desktop case
Keyboard
Lenovo standard usb keyboard
KU-0225 41A5100
Mouse
Micro Innovations
Optical
2 button + scroll wheel
Monitor
Samsung Syncmaster T260HD
1920x1200
16:10
VGA + DVI
