First post, by Sudos
Through some sort of miracle, I've come into ownership of three Gigabyte GA-PCV2 motherboards. it seems these were manufactured by Gigabyte for VIA/iDOT in the mid-'00s, and have a C3 Nehemiah 1GHz re-badged as a "pc1500" chip, and aside from having an unlocked multiplier (the BIOS allows for the setting of up to 133x16, 2.13GHz!!!), the boards are no different than your usual VIA C3 offering. CLE266 NB with integrated S3 Unichrome (non-Pro) IGP, VT8235M southbridge, RTL8100C 10/100, Realtek AC'97 audio codec chipset, single DDR slot, 2x PATA, 2x USB ports and 2x USB2 headers, 1x serial port and 2x serial headers (or so it seems?), 1x Parallel, and a single PCI slot for expansion of any kind.
There's not a lot of information out there about this board or its other few like-model counterparts.
VIA announced these as part of the pc-1 Initiative: https://en.wikipedia.org/wiki/VIA_pc-1_Initiative and, it very well seems VIA sold this through iDOT when that was a thing too, and the manual, original OEM drivers (which isn't a big deal, easy enough) and latest BIOS update (THIS is a big deal... headaches!) were never archived properly on the web archive and have since fallen off the face of the planet. The only thing that sets my boards apart from others I've seen on the internet is that mine have their S-Video and Composite output jacks populated and working.
In my testing, XP SP3 (and WinFLP SP3, which I had install media laying around for) runs A-OK. Debian Stretch runs okay as well, and OpenBSD refuses to boot. booting from USB is tricky unless you dd the ISO file directly to the flash drive. Otherwise, the board will not boot it correctly in some cases for non-windows ISOs. Transfer speed during USB boot is limited to USB 1.1. Plans to test Win2k and 98SE installation and performance are underway as time allows. I've already overclocked one of them to 1.3GHz with fresh compound and was messing around with UT99 and Quake III on it. it doesn't do either half-bad, but the onboard graphics are very lacking in that it limits the screen resolution to 1280x1024 maximum. Definitely needs a better PCI video card of some manner, like a Radeon 9250SE, which would be absolute overkill, I think.
Some pics:
In an attempt to keep the BIOS for this from being lost again, I have the May 24, 2007 BIOS backed up from mine, and I'm attaching it below for convenience of anyone that might come across this post.
GA-PCV2.zip
208.47 KiB
178 downloads
BIOS from May 24. 2007 backed-up from a Gigabyte GA-PCV2 motherboard for the sake of archival.
If anyone has any of these with a newer BIOS, I'd be interested in the file so that I might get it archived properly. The only other Gigabyte board or any other board with the exact same specs I've been able to find is the Gigabyte 6VLE80 board found in the BRIX TA-3 SFF PC that Gigabyte sold many moons ago. However, the BIOS file for that is half the overall size.
Reply 1 of 5, by amstari
Have you tested it with Win 98SE as yet?
I've install Win 98 SE on the same PC-1 motherboard/cpu combo. According to CPU-Z the BIOS on mine is version F2 ID 03/13/2006.
It works great for Windows games but I'm having problems with sound for DOS games, either through Windows or rebooting into MS DOS. I haven't been able to get any AC97 audio drivers that will work as a Sound Blaster. The only options I have in the BIOS are to enable or disable on-board sound. I don't have "On board Legacy Audio". What sound setting does the new BIOS have?
I was able to find some information here and I now have some DOS sound in Windows (sfx in Wolfenstien but no music): VIA AC'97 Sound Blaster drivers for MS-DOS?
Reply 2 of 5, by Sudos
amstari wrote on 2020-05-24, 07:24:
Have you tested it with Win 98SE as yet? […]
Sorry for the late reply... I haven't tried 98SE on this system yet but I've considered it. I need to get a proper MiniITX case for it before anything else, however.
Would you be able to upload a backup of the BIOS ROM your board has, and would you be willing to attach a couple of pics of your board to the thread? it's very rare that there are others with these boards... I don't even know what these boards I have came out of, it'd be nice to see one that's in a case.
Reply 3 of 5, by 4xtx
Hi, I also have the same board 😀
I can't get the sucker to boot of any USB though..
Note mines missing the composite output but has the same revision number as yours..
I'm also running an old BIOS so unsure how to back it up or update it (given I can't boot anywhere)
    718.94 KiB
    1.61 MiB
    934.97 KiB
YT: https://www.youtube.com/@techdistractions
Reply 4 of 5, by Sudos
4xtx wrote on 2020-07-30, 10:08:
You need to think outside the box to get this board to boot off a flashdrive, it's a bit picky. CD-ROM boot is preferred for it.
for USB, you need to basically dd an ISO onto a flash drive instead of using rufus the proper way. This works for Linux and the BSDs, and *only* for WinFLP, since XP needs some extra hackery that Rufus does to be bootable off a flash drive that you can't do as an ISO image directly to the flash drive.
That's why I'm running FLP in the first post, it's what I had that could be booted in such a manner, because of the way the installer is handled in a similar way to Vista/7/8/10 after it.
In fact, I think FLP's installer was an earlier version of Vista's before it got flashy, but I could be wrong.
I'd also like a dump of your BIOS when you get it fully working, if you don't mind. any copies we can get off these boards and cleaned up so they're flashable is another step towards keeping these things documented since Gigabyte apparently never wanted to, and neither did the brands that used them as base boards. and, yours is a lower-end version of the board, so it'd be interesting to know what the date on your BIOS is compared to mine.
Reply 5 of 5, by 4xtx
Sudos wrote on 2020-11-08, 21:30:
Sure - I will get around to this shortly. I've got it packed away for the moment.
I did get the board to boot by preparing a CF2IDE setup. Windows 98SE (and ME) works well despite the drivers being a real challenge (this board was really designed with XP in mind).
From memory I was able to boot FreeDOS off USB and also tried the "DOS7" unofficial CD-ROM which worked fine too off USB.
Games actually run OK and the Via Unichrome (non Pro) works well in DOS and supports the fast video modes on Phils benchmark kit.
It also holds up OK in Windows, I was able to play DX stuff Monster Truck Madness and Extreme-G 2 with hardware rendering.
Only downside was DOS sound as there's no way to get it working and I wasn't that interested in running the SB emulator (as impressive as it is) under Windows..
For now I've got an AudioPCI style card in the PCI slot but the sound is below average (especially FM music) - this being said I didn't spend much time investigating so far, could just be the driver I was using.
I also picked up a Nvidia 6200 PCI model which I will test at some point. Keen to see how it goes vs the IGP
