Reply 20 of 22, by kokerich
Another update. Keyboard problem solved. It is a "software" problem, in the BIOS setup option "Turbo switch function" must be disabled. Strange but it solves the problem and the keyboard works normaly. Another interesting thing is that option does not disable turbo switch for real, hardware switch on the motherboard works with no problem via jumper. Also I added FPU unit, now the board looks more complete.
