First post, by matze79
i made a little Adapter allowing connection of a microsd card to the lpt printer port.
due do the fact chinese microsd modules with levelshifter are cheaper then a single mmc slot, i used a ready made module 😀
104.4 KiB
102.87 KiB
simple single sided PCB.
11.71 KiB
No downloads
For Homemakers:
etch me.pdf
73.42 KiB
301 downloads
i used this Adapter:
https://www.ebay.de/itm/5Pcs-microSD-TF-Card- … 872.m2749.l2649
Note that this is not very fast, around floppy drive speed, depending on cpu speed.
And here is Nilquaders Driver, its most stable one i found.
There is also SPPD 1.1 Driver which runs also with some SDHC. i need to swap two Pin's in Code so both drivers can be used.
Swapping MicroSD is not possible without powercycle.
11.71 KiB
No downloads
Thanks
Matthias
    dos_093.zip
    2.3 KiB
    312 downloads
    Nilquader Driver - for Schneider Euro PC and PC XT/AT (Only SD, no SDHC!)
Reply 1 of 19, by root42
What IS this? I am intrigued. But... why? I mean, ok, back in the day we used parallel port Zip drives and the like.
YouTube and Bonus
Reply 2 of 19, by stamasd
That looks like it could be useful in particular situations. Very nice, thanks for sharing!
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 3 of 19, by matze79
its very handy, very small but slow.
But its much better to install borland C 3.1 from microsd instead of changing several floppys 😁
Or if you have a XT Clone with floppy only.. or a XT with 360Kb floppy and you simply want to drop some files easily.
The "Nilquader " Driver needs only ~1,5k RAM and implents SPI in Software on LPT.
Reply 4 of 19, by Jo22
Very nice! 😁 say, does it work with normal " full size" SD cards, too ?
Reply 6 of 19, by matze79
And now ? this driver will not work with this adapter unless its modified and pin's are matched in sourcecode.
Also it's a outdated version.
Reply 7 of 19, by matze79
Yes if you add a normal sized shield, maybe connectors for different SD Shields can be added to the breakout PCB.
But not all cards won't work 😀
Reply 8 of 19, by Jo22
Thanks for the info! 😀
Reply 9 of 19, by mcobit
Also worth noting:
Not every sdcard module has a voltage regulator on board. Even if it might work without: a levelshifter on the datalines would also be recommended if not on the module. SD Cards work on 3.3V
Reply 10 of 19, by mcobit
Here is my ghetto breadboard version of it 😀
874.27 KiB
928.14 KiB
Reply 11 of 19, by Jo22
Ghetto ? Looks fine to me! 😀
derSammler wrote:
Thanks!! 😁
Reply 12 of 19, by matze79
14.54 KiB
added 3 Resistors, fixing issues with my XT Computer, (SDCard not detected) added Select Jumper for Driver.
Simply switching the Pin's inside the sdppd Driver Source did not work, don't know why, and did no further investigation.
Used a 16GB SDHC with 32Mb FAT16 Parition and SDPPD Driver v1.1 😀
    SDPP11(1).zip
    42.14 KiB
    269 downloads
Reply 14 of 19, by matze79
Only 1bit is used, so don't expect wonders.
speed depends on how fast your computer can bit bang spi.
Reply 15 of 19, by .legaCy
Maybe using some shift registers etc would allow using 4bit's 3-4 times faster.. but also needs to rewrite the driver.
What about using a microcontroller to convert the SPI to the parallel?
of course the driver would need to be rewritten.
Reply 16 of 19, by LordMortiferus
Here are two versions of the SDLPT-adapter by matze drawn in KiCad:
1.46 MiB
The contacts of SPI-reader are directly solder onto the board.
    SDLPT.7z
    16.17 KiB
    219 downloads
Reply 17 of 19, by Hiddenevil
Can these be bought anywhere?
There's an old android saying which I believe is peculiarly appropriate here. In binary language it goes something like this: 001100111011000111100, which roughly translated means: "Don't stand around jabbering when you're in mortal danger!"
Reply 18 of 19, by LordMortiferus
Sort of...
Everything you need is in the attachment above. I can add gerber and BOM as well.
I probably going to distribute my surplus PCBs and parts when I find the time and motivation for it, but that may take a while.
Reply 19 of 19, by matze79
There is a better Driver Release now, with better SDCard Support.
