First post, by browny1978
Through freecycle I've acquired a couple of SIS motherboards. One is a 661GX mobo with a 2.93ghz celeron, and the other one is a SIS 760GX mobo with a 3100+ Sempron. Both will run Win98, but which is better?
The 661GX supports the P4 Extreme Edition CPU, and 760GX supports Athlon 64 x2, so I suppose the 760GX is the better one?
I'm just after a bit of guidance as after P3 and Athlon XP I loose track.
