First post, by Compo Simmonite
Asus P3b-f board, tried using aflash to update to latest bios. During this the dog trod on the power strip and cut the power, board now wont boot.
Tried hot swapping the bios chip into a p2b board when running and then running aflash, says its erased and programmed it with the p3b bios after the incompatibility/different version warning but if i then swap it back into the p3b board it still doesnt boot.
Any ideas/help?
Cheers!
