First post, by lucidphreak
Greetings.. I have a 750c with a bad screen that I am connecting to a VGA monitor for use in playing with old BBS software, phreaking apps, etc - all DOS apps.. I have DOS 6.22 loaded and I have downloaded the software I've been able to find online - but when DOS starts up I get a "PC Card Services Not Started" Message....
My goal is to use my PC Card/CF adapter as a hard disk so I can get files back and forth between my archive and the laptop... Eventually I will have PC Anywhere running so I could xfer that way with a cable - but for now I would like to get the CF solution working.
Does anyone have familiarity with this device and getting the PC Card Services working?
Thank you!
Reply 1 of 1, by lucidphreak
found the answer with some searching an I am now a happy PCMCIA/CF Card hard drive individual!!!
Re: What retro activity did you get up to today?
Thank you vogons you solved both this problem as well as my Unisys CWD problem!!!!
