First post, by exs1s
EDIT - WARNING: DO NOT TRY AND INSTALL AN IDE TO CF ADAPTER IN AN LTE LITE MACHINE. IT FRIES THE HDD CONTROLLER.
Hi Guys,
I've had some real success in the past with replacing old failing hard drives with Compact Flash cards and SSD drives. For example, I've successfully installed a mSATA SSD drive in an old IBM ThinkPad, a Compact Flash card in a Compaq LTE 5000 series, both with 2.5" IDE adapters; and many many desktops with Compact Flash IDE adapters. All have worked flawlessly.
I'll just make it clear that the old hard drive still works, although it is starting to make noises indicating it will soon fail. I also have another identical hard drive that works fine from another machine. Same problem with both hard drives and machines.
Bt I'm having some trouble with a Compaq LTE Lite 4/25. One of the problems is that the BIOS only recognises 66 pre-defined hard drive types. For example, mine is type 50 (which is the default HDD type for the LTE 4/* models being 120Mb). Types 65 and 66 are technically custom hard drive types but don't actually allow you to specify custom parameters (like type 47 does on some newer models). So that's the first issue. Keep that one in mind, but that's not the main problem. I could probably mask a drive using EZ-BIOS or something similar to get around this.
The next and main problem is that I'm not even sure the original drive is a standard 44-pin 2.5" IDE drive - even though it's presented in the BIOS as such, and has the standard (what looks like) 44-pin connector. The reason I think it may not be standard IDE that when I plug the drive into a 2.5" IDE to USB adapter, the drive powers up, but does not show up as attached - even when I use Windows 10's disk utility. The USB adapter is shown with nothing attached.
Then when I try and connect a standard IDE to CF adapter with a 64Mb CF card installed and the jumper set to master (yes I've also tried slave and no jumper at all), to the laptops apparent 44-pin IDE cable, the disk is completely ignored as if it's not there at all.
I've also tried the SP2504 floppy version (download here) of the BIOS/CMOS setup utility which gives a few more options than the F10 utility - but makes no difference.
So, in summary, the original hard drive is not recognised by my Windows 10 PC (or my Mac) as even a drive via a USB to 2.5" IDE adapter. Yes, the adapter works with other drives. And the laptop doesn't even recognise any other drive is plugged in (except another type 50 drive and that is recognised by the laptop wich verifies the fixed disk controller works OK).
P.S. This problem does not exist on the LTE Elite or LTE 5000 series. I have both of these laptops with CF and IDE adapters working fine. This problem is unique to the LTE Lite series from what I can tell.
Does anyone have any experience with these laptops and their drives? And even better replacing the old drive with something new and more reliable?
file.php?id=57163
Current Models:
LTE Lite 4/25
LTE Lite 4/33
LTE Elite 4/75
Deskpro 386s
Prolinea
Please also join my Facebook Group
Reply 1 of 7, by henryVK
Have you tried using a the USB-IDE interface with a different operating system? I've had drives that Win7 recognized without a hitch and some that it just didn't like. Maybe try Windows XP, if that's an option at all.
Also, some machines apparently just don't recognize CF adapters. I've tested a couple of different adapters on this Toshiba laptop without success. You might want to try SD cards as an alternative.
Reply 2 of 7, by exs1s
Yes to both. I've tried the USB-IDE in Windows XP with another drive and it works great. Connect the Type 50 drive and nothing.
file.php?id=57163
Current Models:
LTE Lite 4/25
LTE Lite 4/33
LTE Elite 4/75
Deskpro 386s
Prolinea
Reply 3 of 7, by Nvm1
Those old drives don't communicate with the parents system what their size and capabilities are like newer drives.
That is why you won't see the drive in W10 on a usb-ide adapter. Those old drives aren't recognized due to this limition on newer systems.
You will need to use another old system to attach the drive and access it after identifying it in the bios what size and geometry it has..
Reply 4 of 7, by exs1s
I have an update on this. I've now tried about 5 different drive solutions. This includes:
  • mSATA with IDE Adapter
  • CF Card with IDE Adapter
  • 4GB Samsung Hard Drive
All of which work in my IBM T23 and T30. None of which work in the Compaq laptop. And interestingly - none of the Compaq HDDs are recognised in my even older IBM 600 series laptop, yet all the above hard drive solutions do work.
I genuinely think that these laptops have some type of proprietary MBR / file system / on-HDD controller or whatever. Absolutely no HDDs, other than the original Conner/Seagate hard drives which were originally spec'd seem to work.
There must be someone with experience of these machines and fitting updated solid sate drives.
file.php?id=57163
Current Models:
LTE Lite 4/25
LTE Lite 4/33
LTE Elite 4/75
Deskpro 386s
Prolinea
Reply 5 of 7, by kleung21
Having the same problem but I have an LTE Elite 4/50cx
IBM OEM
Model IBM-H2344-A4 hard drive
344 mb capacity
915 cyl, 15 heads, 49 sect/track
Can't read it using usb/ide adapter
can't get a tested ide/cf adapter to boot from it.
I know it has a custom Partitoin at the beginning... Don't know what to do with that
Reply 6 of 7, by weedeewee
kleung21, find an old pc with an IDE controller, and hook the drive up to that. Then you'll be able to access the drive... that is, if it isn't dead.
The custom partition is probably the compaq system partition.
Reply 7 of 7, by kleung21
Thank you guys.
As a follow-up. I found that it was the CF - ide adapter that was the problem. I swapped it out and reformatted the CF card. It runs fine even without the BIOS partition.
For anyone that needs follow-up. The compaq lte elite 4/50cx supports the CF-ide adapters... even if missing the bios partition. I am running dos/win311
