First post, by Callahan
Hi folks!
Can someone confirm me that W6-Li supports PII-OD?
I try to run SL3EA and they’re detected as Overdrive 266 and bios is freezing after mem counting with info that say power management is not supported on this tyle cpu. Bios is w6-Li-04 latest i think.
Cpq: ap550(2x1G/256k), sp750(2x900/2MB), 4100@PODP5V83, 5100(2xpII300),w8000(2x2.8).
HP Vectra XU 6/200 2x PIIOD 512MB FPM
Super S2DG2@550/1MB SCSI 15k V5 5500
P4T533-C P4 3,06 Ti4600
V3 3500 AMD k6-III+ GA-5AX
PR440FX-2x PIIOD Voodoo 4500 PCI r320 CT1920
Reply 1 of 3, by Callahan
I confirmed it by myself: Bios ver 4 does not support PODP at all. My board is rev B1.
Micronics support said that bios downgrade is impossible but they wrote nonsense. I used /mode=3 switch and it worked .
After downgrading to the older version of bios: w6li2m-3 system is functioning with both PODPs with enabled cache.
Only thing is POST display CPU=Overdrive 75Mhz
Reply 2 of 3, by amijim
Hello there, i am reviving my w6-li mobo as well and i would like to ask you what os did you use.I tried to boot ubuntu 8,04 but it didnt boot.All i got is an endless progress bar.
Iwill ZmaxDP
Arima4way
Tyan s2885
Iwill MPX2
Gigabyte GA-7DPXDW+
Compaq SP700
Compaq ml350
Reply 3 of 3, by Callahan
NT4 works.
Now i don't remember how i booted off from cd- pci scsi or integrated atapi...
