mkubiak402 wrote:if "single-sided" doesn't refer to whether there are chips physically on both sides what is it?
The number of banks, i.e. data lines. A single-sided DIMM contains 1 bank, i.e. 64 data lines. A double-sided DIMM contains 2 banks, i.e. 128 data lines.
Most (S)DRAM chips used on DIMMs have 8 data lines, eg. 16Mx8, so a densitiy of 16Megabits per line times 8 lines. That gives you a chip capacity of 128Mbits.
Now, if you stick eight of those on a DIMM, you have 128MB total capacity and 64 data lines, so you've got a 1 bank, single sided DIMM. Generally you'd expect to see 8 chips on one side and nothing on the other, but DIMMs with four on each side also exist, and they are still single-sided.
Conversely, you have 128Mb chips with 8Mx16 organization. Same capacity, but twice the data lines. Four of those make a single bank, eight give you a double bank, even if they're all on the same side.
and if i want to fill it with 3 256mg sticks what do i need to look for? 32M x 64?
[/quote]
You need double-sided DIMMs with 16Mx8 128Mb chips. As for notation like "32Mx64", that's for the whole DIMM and on the whole unhelpful, as you don't know whether it's referring to 8 chips with 32Mx8 (256Mb), or 16 chips with 32Mx4 (128Mb). In this case, neither will work correctly, as the 256Mb chips are too big, and will only be detected as 128Mb, so the DIMM will only be detected as 128MB. 32Mx4 chips are worse, they won't run at all.
>90% of 16-chip 256MB DIMMs will work correctly as they have 16Mx8 chips on them, only DIMMs with 32Mx4 will not, so look for 16 chips and if in doubt, look up the specs of the chips themselves on the DIMM. As I said earlier, good manufacturer-branded DIMMs are generally a safe bet, as unbuffered DIMMs with 32Mx4 chips are outside of JEDEC standards and the chip manufacturers stick to those religiously.
