First post, by hernan43
I have an old Gateway motherboard (440LX?) with a Pentium II 266MHz cpu and 128MB of RAM. The only devices plugged into the slots are a Voodoo3 AGP card, Sound Blaster 16 ISA(IRQ5), and a Music Quest clone card(IRQ7) also ISA.
The mouse I have is USB but it loads into DOS via the Legacy mouse settings in the BIOS.
Any game I play that uses the mouse has audio slowdown/stuttering when ever the mouse is moved. If you don’t touch the mouse everything plays fine.
I’ve tried both the MSDOS official mouse driver and CTMouse.exe. They both have the same issue.
I used to play DOS games via a very similar setup back in the day and did not have this issue so I am surprised that it is an issue now. With the exception of the midi card everything is period original.
I’ve tried messing with the IRQs and flipping settings in the BIOS to no avail. What else can I try?
