Ultimate AMD K6-3-500 build advice ?
First post, by Intel486dx33
I am working on building the Ultimate AMD K6-3-500mhz computer right now. I am posting from it now.
I have it loaded with Win98se and I.E. 6.0.2
Performs well and is very stable.
Purpose:
Best AMD K6-3 CPU performance and audio sound for it's time.
Time Period 1990's , AMD K6-3 time period 1999.
Games and music - DOS and Win98 dual boot.
Best game compatibility in DOS and Win98.
Compatibility with most games in DOS and Win98.
Current parts in use:
Motherboard - Soyo-SY-5EHM, baby ATX, 3-ISA, 3-PCI, AGP
Cache - 512kb.
RAM - 2x256mb. = 512mb. total
CPU - AMD K6-3-450 over clocked to 500mhz.
Chipset - VIA
Graphics - Nvidia AGP Geforce MX 420
Audio - Sound Blaster AWE64, ISA
Network - AMD family PCI ethenet
Hard-drive - IDE , Seagate barracuda 500gb. 7200rpm.
DVD - IDE
Floppy drive 1.44
Case - Lian Li silver aluminum desktop.
Power supply - Some 300watt PSU ATX
Other Parts I have avalaible:
Voodoo-3-3000 AGP
Nvidia fx 5500 PCI
Cirrus logic and S3 , ISA graphics cards.
SB Vibra 16 with Yamaha OPL-3 , ISA
SB Pro 2.0 with Yamaha OPL-3, ISA
Yamaha Audician-32 , OPL-3, ISA
SB live 5.1, PCI
SB live, PCI
SB Audigy-2zs , PCI
SSD
CF Card
Wiki:
"The K6-III, code-named "Sharptooth", is an x86 microprocessor manufactured by AMD, released on February 22, 1999, with 400 and 450 MHz models. It was the last Socket 7 desktop processor. For an extremely short time after its release, the fastest available desktop processor from Intel was the Pentium II 450 MHz. However, the K6-III also competed against the Pentium III "Katmai" line, released just days later on February 26. "Katmai" CPUs reached speeds of 500 MHz, slightly faster than the K6-III 450 MHz. K6-III performance was significantly improved over the K6-2 due to the addition of an on-die L2 cache running at full clock speed. When equipped with a 1MB L3 cache on the motherboard the 400 and 450 MHz K6-IIIs is claimed by Ars Technica to often outperform[1] the more expensive Pentium III "Katmai" 450- and 500-MHz models, respectively."
History:
Lian Li Industrial Co., Ltd was founded in 1983, and is based in Keelung, Taiwan.
    102 KiB
    692.65 KiB
    127.96 KiB
    119.07 KiB
    106.81 KiB
Reply 1 of 33, by Intel486dx33
More photos :
    639.22 KiB
    1.3 MiB
    244.28 KiB
Reply 2 of 33, by PARKE
Maybe a read through the thread:
Marvin, the Paranoid Android//Video// "AMD K6 3DMARK, aiming for stars." can help you.
Don't worry about the K6 III+ being from 2000, the Gf MX 420 card you chose for your project seems to be from 2002 ?
Reply 3 of 33, by Intel486dx33
Yes, I have been viewing Philscomputerlab.com videos for recommendations.
What I have learned:
1 stick of 256mb. Performs best.
For DOS games the PCI Nvidia FX5500 works fine.
My questions are:
1) What sound card is most compatible with old DOS games ( SB PRO 2.0, Yamaha Audician-32, SB Vibra-16 with Yamaha OPL3, SB AWE64 ) .
2) Should I use a Voodoo-3-3000 AGP in a AMD K6-3-500mhz. DOS gaming computer or should I save it for a more powerful computer like a P3-1ghz ?
3) Should I just make this a DOS gaming computer and not windows ?
Reply 4 of 33, by BinaryDemon
I’m guessing the Geforce 256 is the real unicorn but Geforce2 MX is acceptable alternative.
Check out DOSBox Distro:
https://sites.google.com/site/dosboxdistro/ [*]
a lightweight Linux distro (tinycore) which boots off a usb flash drive and goes straight to DOSBox.
Make your dos retrogaming experience portable!
Reply 5 of 33, by Ponjiayulady
I also have one like this,very good performance, can compete to Pentium ii
167.91 KiB
275.32 KiB
Reply 6 of 33, by PARKE
That is a totally different source.
Your K6 thread uses the term 'Ultimate'.
Unless you use a -very- different rationale for the term 'Ultimate' it could be to your advantage to check out the 'aiming for the Stars' thread:
Reply 7 of 33, by Intel486dx33
PARKE wrote:
Yes, I have been viewing Philscomputerlab.com videos for recommendations. >> >> That is a totally different source. Your K6 thr […]
Well, I am not to concerned with Overclocking. This Soyo motherboard only supports 5x multiplier at 5x100mhz or 5.5x66mhz.
So 500mhz is as high as I can overclock this 450mhz. CPU.
500mhz. is fine for Windows-98se. and more than enough for DOS games.
But is it enough for Voodoo-3 video card games ?
What I mean by Ultimate is best game compatibility in DOS and Windows 98se.
What I am most concerned about is choosing the best sound card and video card for DOS compatibility, performance and quality.
Voodoo-3-3000 AGP
Nvidia fx 5500 PCI
SB live 5.1, PCI
SB live, PCI
SB Audigy-2zs , PCI
Reply 8 of 33, by cyclone3d
Set the multiplier to 2x and the CPU will read it as 6x.
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 9 of 33, by Intel486dx33
I don’t think this CPU can handle 600mhz.
Maybe 550mhz ?
What motherboard settings do I need ?
Here is the manual:
https://stason.org/TULARC/pc/motherboards/S/S … um-SY-5EHM.html
I have the CPU voltage set at 2.2v
Reply 10 of 33, by PARKE
[quote] If you want the maximal performance I suggest a 0.18 micron K6-2+ or K6-3+ depending on the speed and money you want to throw at it. If the CPU requires a 6x multiplier and your motherboard doesn’t provide that in the manual
remember that you can set your motherboard to 2.0x and the CPU will act as it is 6.0x
this is available with the K6-2 CTX cores and later.
[unquote]
http://www.amd-k6.com/platform-hardware/
Model /Part // Freq. // FSB(MHz) // // L2 cache // Socket
oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
K6-III+ AMD-K6-III+/450ACZ // 450 MHz // 100 // 256KB // Super socket 7
K6-III+ AMD-K6-III+/475ACZ // 475 MHz // 95 // 256KB // Super socket 7
K6-III+ AMD-K6-III+/500ACZ // 500 MHz // 100 // 256KB // Super socket 7
http://www.cpu-world.com/CPUs/K6-III/AMD-Mobi … %2B-450ACZ.html
K6-IIIE+ K6-III+/400ACR // 400 MHz // 100 // 256KB // Super socket 7
K6-IIIE+ K6-III+/400ATZ // 400 MHz // 100 // 256KB // Super socket 7
K6-IIIE+ K6-III+/450ACR // 450 MHz // 100 // 256KB // Super socket 7
K6-IIIE+ K6-III+/450APZ // 450 MHz // 100 // 256KB // Super socket 7
K6-IIIE+ K6-III+/500ACR // 500 MHz // 100 // 256KB // Super socket 7
K6-IIIE+ K6-III+/500ANZ // 500 MHz // 100 // 256KB // Super socket 7
K6-IIIE+ K6-III+/550ACR // 550 MHz // 100 // 256KB // Super socket 7
http://www.cpu-upgrade.com/CPUs/AMD/K6-IIIE+/index.html
Reply 11 of 33, by Intel486dx33
Motherboard manual.
Reply 12 of 33, by retardware
If your K6 actually runs at 2.2v while having 2.4v imprinted, it probably will be a good specimen which can be nicely OCed.
I'd always use the numbers on the chips themselves.
DSCN9320.jpgMy ones will go to the bay because I'll soon upgrade my IBM 5170 from a DFI K6BV3+ A1 mobo to a Pentium III 1400MHz Baby AT mobo, hoping for better performance with Descent 3 😀
@PARKE
I always thought that K6-3+ officially only went to 450MHz and K6-2+ only to 95/570 or 100/550. Never saw a higher chip. Do they actually exist??
Maybe there are chips listed that were announced but never became available?
EDIT:
Regarding the graphics card, I was looking at the FX 5500 too. However I am not sure whether DX9 is really used by games that were released until the beginnings of the 2000s? Currently have Nvidia Quadro NVS280 PCI (which is internally actually like Geforce 440MX) and Radeon 9250. I so often read that some time the real mode DOS support of many graphics cards got worse... will see when parts are here 😀
Reply 13 of 33, by Intel486dx33
So what is the best setting for this CPU ?
450mhz - 4.5x100mhz
500mhz - 5x100mhz
333mhz 5.5x66mhz
Reply 14 of 33, by retardware
I'd say, if you make sure that the fan on the S7 cooler is adequate, your K6-3 450 will probably run fine at 600MHz.
On the right hand you see the puny original fan of the S7 cooler, which doesn't look very trustworthy, on the left you see the cooler equipped with a quality Japanese fan scavenged from a DLP projector.
Reply 16 of 33, by cyclone3d
Intel486dx33 wrote:
I just don’t know what jumper settings to use. 500mhz appears to be the highest this motherboard supports.
Can you tell by the manual ?
For the CPU bus clock.. use the "Frequency Setting SW1" that is for 100Mhz
Then for the multiplier, use:
5x
5.5x (same as 3.5x)
6x (same as 2x)
JP7, JP9, JP10 are your CPU multiplier settings
SW1 is your bus speed settings.
One thing to note is that I am seeing 6 switches for the bus speed settings which tells me that there are a ton of undocumented settings. It is always fun to play with those as there are going to be some that run the PCI bus and AGP bus overclocked. PCI bus should be good up to about 37.5Mhz and AGP bus is good up to whatever your particular AGP card will handle.
You probably also have some undocumented bus speed settings that are over 100Mhz... probably 105, 110, 112, and maybe 115.
You probably also have 83, maybe 90, and 95Mhz bus speed settings.
A review says that there are settings for 60, 66, 68.5, 75, 83, 90, 100MHz and 112MHz.. but with that many dip switch settings there has to be more. With 6 switches, you have 64 possible different combinations.
You can always look up the spec sheet of the clock generator that is on your board to see exactly what it supports and work out the switch settings from there without have to write out a graph of the different settings yourself.
Playing with old SS7 boards was a blast back in the day.
Come to think of it, I may have the same board at home.
YMF7x4 Guide
Reply 17 of 33, by LunarG
If only I'd known back in the days, that the GeForce 256 would become so rare. I used to have a Creative 3D Blaster Annihilator Pro. It was awesome 😁
WinXP : PIII 1.4GHz, 512MB RAM, 73GB SCSI HDD, Matrox Parhelia, SB Audigy 2.
Win98se : K6-3+ 500MHz, 256MB RAM, 80GB HDD, Matrox Millennium G400 MAX, Voodoo 2, SW1000XG.
DOS6.22 : Intel DX4, 64MB RAM, 1.6GB HDD, Diamond Stealth64 DRAM, GUS 1MB, SB16.
Reply 18 of 33, by meljor
Ok, some facts now.....
Overclocking a (mobile) k6-3+ to a really stable 600mhz or higher is not that easy, it will run etc. but getting it perfectly stable can be a challenge. So overclocking a normal k6-3 to 600mhz? GOOD LUCK getting that stable. 500mhz is about the highest setting you can use, and not all of them can reach that.
Beside all this, the 5,5x multi is a better setting for these cpu's as it is in most cases faster compared to the 2x (=6x). Don't know why! Using the 5,5x 110mhz is perfect for a k6-3+ as it also gives you the higher fsb.
About the voodoo3: some ss7 boards with VIA chipset used a cheaper linear voltage regulator for agp, instead of a switching regulator. On these boards the voodoo3 3000 can be too much, also other high end cards like the TNT2Ultra or Geforce2 Ultra could be best avoided. Using the versions that are a tad slower (but draw less current) like the v3 2000 or Banshee or a normal TNT2 is the way to go on those boards, MX cards draw even less current.
So check what sort of regulator is on your board before using a voodoo3 3000 agp. Pci versions are fine.
Reply 19 of 33, by Intel486dx33
I might try 550mhz.
And the Voodoo3-2000 agp.
What about the sound card ? Which is best for DOS game compatibility and sound quality ?
SB AWE64 ISA
SB Vidra16 with Yamaha OPL3
Yamaha Audician 32 OPL3 ISA
