First post, by tensi0n
Hello,
I am in need of a EISA configuration utility program for my Lion Computer Nice Super EISA Motherboard. If anyone knows of a version that will work with this board or a copy of the original, that would be helpful. Thank you.
Reply 1 of 2, by eisapc
Usually any ECU should work as long as you have the matching *.cfg and probably *.ovl file for your board.
You can try there:
The source files with the various ECU's etc are now online. Link is on the main EISA page:
http://108.59.254.117/~mR_Slug/EISA/
eisapc
Reply 2 of 2, by NJRoadfan
The generic AMI EISA configuration utility will work fine. The board uses this cfg file: http://108.59.254.117/~mR_Slug/EISA/!SIS0001. … G/1993-07-29v2/
