First post, by red_avatar
- Oldbie
So, I finally decided to give the HP Vectra Pentium 75 a friend donated a modern make-over. I already added 8MB more memory to a total of 16MB and now wanted to replace the VERY noisy drive with a compact flash drive. This worked with my IBM PCs who are now very quiet and faster than before but this HP Vectra is really a LOT harder than the IBM PCs.
Basically, I got an IDE-to-CF adapter and a 2GB CF card. I used fdisk to set a new active primary partition and formatted the card from a DOS 6.22 boot disk (it recognized about 250MB whereas IBM DOS would recognize all 2GB) and that worked to boot from the drive. I then used a GoTek to try and install DOS 6.22 completely and ... I keep getting read/write errors. DOS install lets you retry though so eventually DOS got installed and the drive would boot in DOS 6.22.
Next step was Windows 3.11. Using the installation disks on my Gotek, I started setup and very quickly ran into more drive read/write errors but this time, setup won't let me retry so installing Windows 3.11 like this just won't work. I thought "maybe it's the Gotek?" and started to copy the files to the C drive hoping to run installation from there but even just copying, gave me errors - something like "sector not found on drive C".
Now, I tried another 2GB CF card, I tried another IDE-to-CF adapter and the result is the same. Might it be the BIOS flipping out over it being a 2GB drive (it sees it as a 270MB drive in the BIOS) or what is going on?
Retro game fanatic.
IBM PS1 386SX25 - 4MB
IBM Aptiva 486SX33 - 8MB - 2GB CF - SB16
IBM PC350 P233MMX - 64MB - 32GB SSD - AWE64 - Voodoo2
PIII600 - 320MB - 480GB SSD - SB Live! - GF4 Ti 4200
i5-2500k - 3GB - SB Audigy 2 - HD 4870
