First post, by athlon-power
- Member
Earlier today, I got a second TNT2 in the mail- a 32MB standard version from Creative Labs. Because of this, I now have two TNT2 cards- the other is a 16MB TNT2 Pro. I have enough leftover parts to make a second, quite competent Win98 gaming PC, with my old Gateway Tabor III motherboard (essentially an SE440BX-2, though different in a few ways), and as I was finally going through the steps of running the kinks out of the system (switching PCI cards in response to hardware conflicts, etc.) when it suddenly stopped doing much of anything.
I will turn the PC on, and it will give no video. It gives no error beeps, and seems to be running fine, but the numlock key does not change the numlock light at all. Before this, I had a few issues, but these were all ones I was able to run out of the system, at least the ones I had before whatever this is.
- PSU Failed. It did no damage to the motherboard, and this issue came up a while after the fact. There was no smoke, no sparks; the system just wouldn't even power on. I changed out the PSU, and the system worked.
- Had to mess around with the CD-Drive's IDE selector because it was set as a slave drive on an IDE port with nothing else on there.
- The floppy drive never worked, always acting like I had hooked it up wrong. Wasn't ever able to fix that before this problem.
- There was a resource conflict between my Crystal 4281 PCI sound card and something on the motherboard when it was installed in PCI Slot #2. This problem has been around since I first got the motherboard.
Here's what I've tried to fix this problem:
- I have disconnected all of the IDE drives, cables, and disconnected all of the power cables to the drives, starting with the floppy, going to the HDD, and then to the CD drive.
- I have removed all other cards from the system (I only had that PCI sound card and an ISA network card installed).
- I tried different video cards, none of which fixed the issue.
- I took out the BIOS coin cell battery to try and hard reset the BIOS. Again, no luck.
Interestingly enough, when I remove the RAM, it gives me the "I'm pissy, put RAM in me" beeps, so it gets to the point to where it checks for RAM, but somewhere beyond that, the system seems to lock up and cannot POST. I'm out of ideas on this one.
Specs of it so far:
Intel Pentium III Coppermine 600MHz
256MB PC133
nVidia TNT2 Pro 16MB AGP (Switched temporarily to GeForce FX5200 256MB AGP while trying to figure out if the video card was dead- it is a known working card, but I tried changing it out anyways to see if it would fix the problem).
WD400 40GB IDE HDD
Some 56x CD-ROM drive of some kind, generic IDE
Generic 1.44MB 3.5" floppy drive
Gateway Tabor III
Where am I?
