First post, by bofh.fromhell
Got this TX97-X rev 2.04 with this odd problem.
Any single plane CPU, regular Pentiums, K5's etc, work just fine.
But if the CPU want dualplane voltages, no go.
No POST, no beeps, no nothing !
And since I've had this mobo from new I'm pretty sure I had a 200MMX in it from the start.
Now the MB is very finicky about memory, slot 1 doesn't seem work at all.
Tho I only have 2 sticks with <128MB PC66 memory that works at all with it, so that could be a part of that.
And I remember the "booting without any jumpers installed" incident of '10 with this very motherboard.
Possibly something could have been fried in this unfortunate event?
Anyways, its such a weird problem I wanted to share.
Maby some vogons wiz has some ideas ? =)
Reply 1 of 16, by H3nrik V!
Sounds kind of like the voltage regulator for Vcore is defective ..?
Reply 2 of 16, by bofh.fromhell
You are probably right.
A closer inspection revealed this lil' bugger:
Sure looks like its had a hot moment, or several.
Anyone know how I would go about measuring this ?
Reply 3 of 16, by H3nrik V!
bofh.fromhell wrote:
You are probably right. A closer inspection revealed this lil' bugger: […]
Beautiful, they actually made the effort to write what IC it is in the silk screen. Data sheet here
https://www.analog.com/en/products/lt1084.html would probably be the regulator it self, or one of the resistors. Is Vcore BIOS adjustable or through jumpers?
Reply 4 of 16, by bofh.fromhell
The TX97-X has 3 jumpers to adjust vcore, or 4 jumpers from rev 3.
TBH I'm lost when it comes to most components.
Tho my amateurish searches comes up with MOSFET parts (?).
A pic of the surrounding area.
Top left are the vcore jumpers, set to STD for single plane CPU's or 2.8v if a dual voltage CPU is installed.
Reply 5 of 16, by H3nrik V!
Yeah, can't figure out, how the VID jumpers does their job, unless the Dual Plane CPUs have totally other pins for VCore, than the single planes did? I doubt it, though.
However, I think, I would as a first shot, try to see if I could get an LT1084 (as the silk screen on the board states) off from eBay in the right foot print, and change and see. Next step would be finding the resistors or maybe the transistors next to the jumpber block to see if they'd suffer damage. However, it doesn't seem so from the picture ..
Reply 7 of 16, by meljor
Just make sure the mmx gets a good active cooler and it should work fine at 3.2v just like the non-mmx cpu's. If only the mmx doesn't boot it's probably the cpu that is dead (due to the regulator dying perhaps?)
Reply 8 of 16, by bofh.fromhell
Any dual vultage CPU wont even post.
And as the jumpers are the same for a regular pentium and the MMX variants theres no confusion there.
And all my CPU's work, well they atleast they did =)
Reply 9 of 16, by bofh.fromhell
rasz_pl wrote:
RFD3055 LT1084 NDP603 are probably interchangeable in this design
mosfets usually go bad short, so buzz it out with a multimeter
Just did this.
Beeps however i measure it.
Ya sure it can be measured in place ?
Then again its no biggie putting a new one in.
If it fixes it, sweet.
And if not, well its kinda broken anyway =)
Reply 10 of 16, by bofh.fromhell
Any chance this is compatible ?
In my mind it should be perfect since it looks the same, tho I realize this could release the smoke =)
I am utterly clueless when it comes to stuff like this.
No idea what stuff to check for.
Reply 11 of 16, by rasz_pl
blown
Any chance this is compatible ? https://i.imgur.com/qN9LPaOm.jpg In my mind it should be perfect since it looks the same […]
its perfect .. if your CPU requires 5V 😀
yeah, you need a proper mosfet there
Reply 12 of 16, by H3nrik V!
rasz_pl wrote:
blown […]
blown
Agreed - this is a 5V regulator.
WTF .. The silk screen says LT1084, but yeah, @rasz_pl is right, that IS an "FD3055" MOSFET in TO-252AA case, as per datasheet: http://www.mouser.com/ds/2/149/RFD3055SM-100347.pdf
Reply 13 of 16, by H3nrik V!
A pic of the surrounding area. Top left are the vcore jumpers, set to STD for single plane CPU's or 2.8v if a dual voltage CPU i […]
Looked a little more at it after realizing the blown part was a MOSFET. Here, in the upper left corner (position U13) is the HIP6008, which is a "buck" switch-mode regulator, which is the part controlling the MOSFET, so yeah, sound very reasonable, that the MOSFET is blown as rasz_pl wrote.
Reply 14 of 16, by H3nrik V!
Funny stuff: http://pdf.datasheetcatalog.com/datasheets/228/75664_DS.pdf The HIP6008 actually does all the jumper->voltage stuff 😀
Reply 15 of 16, by bofh.fromhell
Ty all =)
Now I just have to find a replacement nearby.
