First post, by supaplex
Hi there,
I am having difficulties with using EMM386. When enabled it causes the system to freeze in certain situations. One example would be using edit.exe, the moment I press F10 system freezes and beeper continues to beep.
I've tried everything including loading emm386 with a minimum set of functions, cleaning startup files from loading other drivers, swapping RAM with different sticks, disabling any Shadow options in BIOS. Nothing seems to help. It is so annoying as everything works fine if I load the system on my Slot 1 motherboard.
What am I missing?
Any help would be appreciated.
Thanks!!!
