First post, by Ti200
Hello all, im new in this forum. I like retro pc and i need some advices for my pentium iii config.
I have P6i440BX/B1S with latest bios and pentium iii 550mhz katmai core. It is worth to upgrade with a coppermine cpu?
How much faster is coppermine over katmai with same clock? And it is better a slot 1 coppermine cpu or a socket 370 coppermine with slocket?
For the last, i want to know if the catalyst 6.2 are good for a radeon 9000, or there are some older version that can perform better.
I run windows 98 in this pc. For example, i notice some slowdowns in games like half life, even in 640x480 opengl.
Thank you in advance for your advices.
| P3 550 | 384MB RAM | R9000 64MB | Creative ES1370 | SSD 120GB | DVD-ROM |
| P3 1000 | 512MB RAM | Ti4200 128MB | Creative SB0220 | HDD 20GB | DVD-ROM |
| P4 3.06 | 1.5GB RAM | 6600GT 256MB | SiS 7012 | HDD 40GB | DVD-ROM |
Reply 1 of 31, by dionb
Hello and welcome!
The thing with retro stuff is that it's all ancient and glacial compared to an i7 or Ryzen, so you don't need or indeed want to upgrade for the sake of it or for getting the best possible performance, otherwise just buy that new box. It's just about doing whatever you want to do with the old stuff. If what you want to do is some games that run just a bit too slowly on a Katmai, then yes, it makes sense to upgrade to the Coppermine, at least if your motherboard supports them.
As for slot/socket - the performance is identical, but you obviously need a slocket (and one that supports Coppermine) to run an So370 FC-PGA CPU on a Slot 1 board. Conversely, the FC-PGA CuMines are more plentiful and tend to be a lot cheaper than slot versions.
If you're seeing slowdowns at all resolutions, it's an indication something other than the GPU is the bottleneck, something like the CPU. Can't comment on specific versions - I run a radeon 9000 in one system, but that's an nForce3 system with Phenom II quadcore running modern Linux, so a completely different kettle of fish regarding both performance and drivers.
Reply 4 of 31, by Ti200
Hi and thanks for the reply.
As for hl1 i can test it in my other piii 1ghz system, of course the config is different.
What i mean before is if piii coppermine on slocket is better than the slot1 counterpart or viceversa, for motherboard compatibility. Eventually, i have a spare 600mhz coppermine socket 370. I need only the adapter.
I know my mb is coppermine compatible with the latest bios.
I need to understand only if the performance gain are worth the money. There are some katmai vs coppermine benchmarks?
For the radeon 9000 there are also some tweaks i can do for better performance?
Reply 5 of 31, by PARKE
Here some 3DMark99 results I harvested over time:
(the 550 is Katmai, the 600E is Coppermine)
cpu points // cpu // motherboard
8378 // 550 MHz SECC // ASUS P3B-F
8397 // 550 MHz SECC // ASUS P3B-F
9151 // 600E MHz SECC /100 // ASUS P3V4X
9317 // 600E MHz SECC /100 // ASUS P2B-S
9347 // 600E MHz SECC /100 // ASUS P3B-F (oem)
9348 // 600E MHz SECC /100 // MSI 6163 Pro
9361 // 600E MHz SECC /100 // ASUS P2B-S
9408 // 600E MHz SECC /100 // ASUS P3B-F (oem)
9417 // 600E MHz SECC /100 // ASUS P3B-F (oem)
9443 // 600E MHz SECC /100 // ASUS P3B-F (oem)
9447 // 600E MHz SECC /100 // ASUS P3B-F (oem)
Reply 7 of 31, by RaverX
Half Life should run very good on that system. Maybe the problem is somewhere else, missing drivers, not enough RAM, bad hardware. What's the exact model of the videocard? Radeon 9000 seems a generic description to me. If it's a 9200SE with slow memory on 64 bit, well, that can be the problem, but even with that HL1 should run more than fine on 640x480. Are you using the original release of the game? Steam version is much slower, but I don't think it runs under Windows 98... not sure though.
Reply 8 of 31, by Ti200
Mine is a radeon 9000 series rv250, 128bit, bandwidth 6.4gb/s, system ram is 384mb pc100.
I have installed catalyst 6.2 for windows 98 se; agp driver for i440bx, agp 2x is enabled, and agp aperture size is 64mb.
Half life is cd release 1005, updated to 1016.
Reply 9 of 31, by Fusion
Half-Life 1 is really hard on the CPU. A 1Ghz + P3/P4 is the only way to gain better performance. No system tweaking, game tweaks etc. will make a difference.
WIP Retro Files
P3 800 | 512MB PC100| PCI V3 3000 16MB @ 195/195 | CT4780 SB Live! Value| WinME
P3 450 | 128MB PC100| AGP TNT2 Pro 32MB | CT4170 SB16 | MS-DOS 7.10
A64 2.4 | 2GB DDR1 | PCI-E Radeon X800XT @ 575/575 | Win2K
Reply 10 of 31, by dries_86
At 640x480 the original HL1 should run well on a P3 550 Mhz with Radeon 9000. Back in the day I was running the game on a Celeron 600 Mhz, 64 MB RAM and an Intel i810 4mb VRAM GPU and got OK performance (not 60 fps though). So with your system you should play smooth on that res.
Have you tried to run 3Dmark 2001SE on your system? This might give you a good idea about the general 3D performance. As mentioned before they might be something (settings, drivers, ...) holding your performance down.
Reply 11 of 31, by Ti200
I cant expect constant 60 fps in this machine, massive slowdowns happen for example with big explosions.
Now i try agp size at 128mb. Ati driver is set to balanced quality, vsync + triple buffering on.
As for 3dmark, which version is better to try?
Reply 12 of 31, by Ti200
i have done the first run of 3dmark2001se. I run benchmark without playing with settings, final score is 3536 pts.
Reply 14 of 31, by Ti200
From device manager, yes, both dvd drive and ssd. I have done another test at 640x480, my target resolution, score was around 3800-3900 pts.
As for chipset driver, i have installed the one present in Phil's website.
Reply 15 of 31, by dionb
No, as far as compatibility goes they are identical.
Tbh I wouldn't bother with an upgrade that small. Yes, CuMine is than Katmai on average, but not day-night faster, and 50MHz (<10%) faster clock speeds also aren't going to make a significant difference.
https://www.anandtech.com/show/399/9
A P3-600E is about 7% faster than a P3-550 in Expendable and about 21% faster in Quake 3.
Quake 3 very strongly favours Coppermine, so is a best-case scenario, Expendable shows hardly any improvement from Coppermine, so is a worst-case scenario.
If you're going to go CuMine, I'd recommend at least a P3-800E, which would give you at least 30% better performance.
Yes, lots - Katmai vs Coppermine vs Athlon was the hot topic in late 1999. See my link above to Anand's benches, but there are lots more out there.
Reply 16 of 31, by PARKE
Maybe a silly question, but you have in your signature:
Why not just play the games that are too demanding for the P3 550 on the P3 1000 machine ?
Everything that you can do to upgrade the hardware of the P3 550 will result in the two more resembling each other.
Reply 19 of 31, by Ti200
It's not a solution for me because if I have to use P3-550 i can't not play a specific title on that machine. Obviously I do not demand constant 60fps, nor to play titles which the PC would not be suitable for.
Regarding hl1, I saw a video where it runs on a machine similar to mine, P3-500, but with voodoo2 sli, and it plays very smooth. Will it also be due to highly optimized drivers? I never used a voodoo video card so I can't give my opinion about it.
