First post, by MKT_Gundam
So my SE440BX has this BIOS version:
I checked on intel site the release notes but dont say about coppermine CPU update. https://downloadmirror.intel.com/3519/eng/RNOTE171.pdf
My mobo dont have OEM logo at booting, only the Intel one.
I dont have a good floppy drive to update the BIOS. The 6.0 will be enough to use coppermine with 100 FSB + slotket?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 2 of 7, by MKT_Gundam
bakemono wrote:
That's the BIOS version I have, and it works with coppermine.
You can tell what cpu clock you use in the motherboard?
I have here celeron 900, P3 700 and P3 1GHz. All are 100mhz fsb.
Reply 4 of 7, by chinny22
The BX-3 is the "OEM" motherboard for the likes of gateway, Dell. The BX-2 is the "official" Intel board which is why you don't have any logo's
If you don't have a floppy, you can use a HDD, just make sure you bypass the startup files by pressing Shift F5. (that's all the boot disk is doing)
Although I'd recommend a Gotek if your messing around with old PC's. Even if its just the 1 drive you install temperately for times like this.
Even with the standard firmware they are useful for troubleshooting.
Reply 6 of 7, by MKT_Gundam
vutt wrote:
In order to support coppermine you also need to have specific hw revision of the board. More info here: http://www.cpu-upgrade.com/mb-Intel/SE440BX-2.html
MIne is a later revison of 754552-200? 754552-303 and the Bios has the P17
