First post, by varrol
I've damaged my AOpen AX6B motherboard by putting bad CPU with slot-to-socket adapter. Ehh, those MOSFETS got so hot that solder came off in small balls. I wonder what else could have died and if it is worth to try to repair. Unfortunately those are (especially plus version) very rare on sale.
MOSFET FDB6030L and FDB6035AL - I've found some on ebay - but not sure if they are not fake:
https://www.ebay.com/itm/1-pcs-New-FDB6030L-F … 6cAAOSwPAxaOi6o
https://www.ebay.com/itm/10pcs-6035AL-FDB6035 … osAAOSwvF1beTO8
Maybe someone know how to find some replacements currently available. I've searched for replacements but all the time hit models even less available...
    fdb6035al.pdf
    94.87 KiB
    39 downloads
    fdb6030l.pdf
    43.65 KiB
    31 downloads
AOpen AX6B+ | P3 1G | 1GB ECC REG | FX5200 | CT4500
AOpen AX59pro | K6-2 450M | 256MB | Rage 128
Asus CUBX-E | P3 1G | 512MB | GF4 TI4200 | YMF719E-S
Asus P3B-F | P3 933M | 384MB | Radeon 9200 | CT4520
Asus P5A | P55C 200M | 256MB | Riva TNT | CT3600
Reply 1 of 5, by SSTV2
PWM IC of that buck converter might have also shorted. Motherboard is definitely worth to repair 😀. You can easily substitute those mosfets with same or better electrical characteresitic parts. Mosfets used in that motherboard are probably obsolete and were discontinued.
Reply 2 of 5, by rasz_pl
those chinese mosfets will be fine, there is no volume demand to counterfeit outdated jelly bin transistors, you have maybe 1 in 100 chance of getting duds
or desolder some from another motherboard of similar vintage
Reply 3 of 5, by Roman555
varrol wrote:
*** MOSFET FDB6030L and FDB6035AL - I've found some on ebay - but not sure if they are not fake: *** Maybe someone know how to f […]
But you didn't mention what package you need (D2PAK or TO220 or something).
I think it's easy to find replacement in the model range of International Rectifier (choose right package!)
FDB6035AL - IRF3707ZSPBF
FDB6030L - IRF3709ZSPBF
[ MS6168/PII-350/YMF754/98SE ]
[ 775i65G/E5500/9800Pro/Vortex2/ME ]
Reply 4 of 5, by varrol
Roman555 wrote:
But you didn't mention what package you need (D2PAK or TO220 or something). I think it's easy to find replacement in the model r […]
It's TO-263 D2PAK
Thanks - I'll check for those
Reply 5 of 5, by varrol
Finally replaced those mofsets - bought exactly the same I've got originally - and all is working fine - stable, all features work 😀
I was not able to solder them as pretty as originally as I did not want to overheat them.
