First post, by windi
- Newbie
Hi
I've had a problem, where my AWE32 has a real Yamaha OPL3 chip, but only 512kB RAM without expansion possibilities. I also have a AWE64 which has enough ram for good soundfonts, but it has the CQM chip which sounds horrible in old adlib games.
I was thinking that the OPL3LPT adapter might be a good solution for sticking to the better wavetable, because with the TSR old 16bit games would output to the real printer port OPL and with 32bit support doesn't matter because I would use those with wavetable anyway.
I'm just asking do you have experience if this combo would work in practice? Does it matter that the real sound card occupies the adlib ports, when loading and using the OPL3LPT tsr? Is sound output to both the card and lpt, or just to lpt? Or does it conflict and crash?
