First post, by HanJammer
- Oldbie
I have a nice old CGA card, but no TTL monitor, so I can only use composite output.
It work's fine when monitor (in fact it's some sort of portable LCD TV) is set to PAL but picture is B/W (and it looks bad when there should be color on the screen - pretty much like in this screen: https://bumbershootsoft.files.wordpress.com/2 … cga_stipple.png
On the other hand when I set this TV to NTSC then I get the colour but image becomes unstable (horizontal waves are going through the screen - I might make some video or screenshot later).
I expect some noise with composite output but not to this extent.
Any advice?
I can test his card with my regular living room TV as well I suppose...
Check out my YouTube channel the "Rusty Bits"
