First post, by PC-Engineer
Hello,
i need some help by repairing the ELSA Gladiac.
On the model that i got are some resistors and capacitors missing. The card doesnt post and keeps cool (after 2 minutes). The Fan is running.
The following parts (on the PCBs backside) are missing:
Near the front of AGP connector: C102, R258, R260
Near the top left edge of the GPU area: C229
for the capacitors i placed a 10 µF (6V) and for the resistors 0 Ohm, but the Card still not responding.
By the fact, ELSA used nVidia reference disign, somone can help me and give me the exact values of the components.
Thanks a lot and best regards
Lutz
1994/1995 - Socket3 - ASUS SV2GX4 / POD 100MHz / 64MB / SCSI - Windows 95
Reply 2 of 3, by wiretap
Use a needle syringe to put some liquid flux under the BGA and reflow it with a hot air pencil. (if it still isn't responding after you replace the missing components with the proper values)
Circuit Board Repair Manuals
My Project List
Reply 3 of 3, by PC-Engineer
Thanks for your advice!
Considering, that the capacitors mostly are used for filtering, the 10µF should work.
@Thirst
It would be helpful, if you could read the values on top of the resistors R258 and R260 on your TI500.
Thanks and best regards!
Lutz
