First post, by Smack2k
- Oldbie
Before i go and buy an M2 Drive wanted to ask a question:
Anyone here setup Phils DosBoxCE config on one of the Dell Thin Clients he mentions? I have both an HP T610 and a T620 SFF Thin both with 8GB RAM in them, but no M2 for the 620 (just the small flash drive it comes with). Wanted to know if there was a decided advantage to setting things up on a T620 vs T610 or is the difference negligable between them when it comes to running Phils setup?
If you also add using external Midi device to the equation, does that change things?
