First post, by 4dam
Hello.
Today I've started project 386 😀 with this incomplete PC.
  • - no graphics card
    - no HDD
    - no FDD
    - only 24x CD-ROM (working)
    - strange 200W psu
    - 386DX40 mobo
    - 8mb ram SIMM 72pins
    - added some GPU (triden 512kb) and working AT PSU, dosen't boot at all
I've started then, some restoration on visual side. Some cleaning.
I spread it into parts and it's time to fix the mobo...
Could you guys tell me what can I do with this strange "fix" by the last owner ?
I have another question about the PSU. Wich connector is proper for power vable ? The voltage switcher making things tricky. ^^
Wish me luck with this!
There will be a lot of work.
Instagram Retro
96Revenge :Intel AN430TX |128 SDRAM | P-MMX 200| WD 10GB 7200 | ATI Mach64 VT 2mb |Diamond Monster 3D 4MB
WIP: 386DX40
Reply 1 of 8, by derSammler
That's not a fix but a very, very bad repair of a battery leakage. See the green stuff on the chips around? You have to remove all those and rework the damaged area.
The power cable will only fit in one. The other connector is for powering a monitor.
Reply 2 of 8, by 4dam
Yup, but take a look. The connector that should be for monitor is with voltage switch. I'm asking because I'm not really sure that it isn't replaced or It should be connect with other type of cable to the power source. It will be better to check, how it looks inside. I will post photos when I'll do that for info.
Instagram Retro
WIP: 386DX40
Reply 3 of 8, by derSammler
The voltage switch is for the whole PSU and nothing unusual. You set it according to your mains level. If you're in Europe, 220V is fine. If you're in the US, switch it over to 110/120V.
Reply 5 of 8, by SirNickity
Placement doesn't mean much, it's just what was convenient for the designers. But even if you somehow manage to get a cable with the wrong connector on it, it's in parallel with the input socket, so it doesn't actually matter which one is an input and which is an output.
Well.. OK, that's not totally true. The input usually passes through the power switch first to control both the output socket and the PSU itself. So if you were to accidentally stumble upon a rare power cord with the wrong connector, the power switch would do nothing except switch the now-useless "other" input, and the PC would stay on any time it's plugged in. Otherwise it would be fine.
Reply 6 of 8, by 4dam
Thanks for advices. In the meantime, I've retrobrited the front panel.
Looks nice I think. 😊
Instagram Retro
WIP: 386DX40
Reply 7 of 8, by chinny22
I prefer PC's with missing parts, forces you to think about what to put in it, rather then just going with whatever it happens to have installed already
Reply 8 of 8, by 4dam
Actually this computer dosen't have any HDD, floppy, graphic cards, just mobo, case and PSU. 😊
Instagram Retro
WIP: 386DX40
